JIDE Design
JIDE Design
Postby oomer » Tue Sep 12, 2017 1:15 pm
I got the evaluation copy and I couldn't figure out how to visually design using JIDE. I couldn't get it to work on Eclipse. I downloaded Visual Designer for JIDE and I can only put Frames and Bars there, no other components. What am I missing?
oomer
Re: JIDE Design
Postby JIDE Support » Tue Sep 12, 2017 1:22 pm
Visual designer is only for the docking framework and the action framework layout. It cannot be used with other GUI designers. You can add other jide components to other GUI designers. Most of them should work.
Re: JIDE Design
Postby oomer » Tue Sep 12, 2017 2:00 pm
JIDE Support wrote:Visual designer is only for the docking framework and the action framework layout. It cannot be used with other GUI designers. You can add other jide components to other GUI designers. Most of them should work.
Ok, so, I have WindowBuilder in Eclipse. How do I see JIDE components there?
oomer
Re: JIDE Design
Postby JIDE Support » Tue Sep 12, 2017 3:09 pm
You add jide jars to WindowBuilder and select the JIDE components to be used. As I said, not all JIDE components work in the GUI builders but, most commonly used ones should work.
Re: JIDE Design
Postby oomer » Wed Sep 13, 2017 5:01 am
JIDE Support wrote:You add jide jars to WindowBuilder and select the JIDE components to be used. As I said, not all JIDE components work in the GUI builders but, most commonly used ones should work.
Thank you so much for bearing with me, I'm a bit new to this :)
I figured on Palette Manager, I can add JARs. No matter which JAR I added from there, I see the components in the list, I check them but then they come empty in the palette. What am I doing wrong?
Edit:
I got it, thank you very much!
oomer
Users browsing this forum: No registered users and 101 guests
