Show the target column in QuickTableFilterField
Postby orome » Wed Feb 01, 2006 2:56 am
In thunderbird (Mozilla email-client) there is also something linke a QuickTableFilterField (upper right corner). If a special column for filtering is selected, then this column is written with a light gray color in it. After clicking in the field (to enter a filter string) the text of corse disapear.
Thanks - Andreas
orome
Postby JIDE Support » Wed Feb 01, 2006 8:27 am
It's a good suggestion. We will add it.
Postby orome » Wed Feb 08, 2006 6:02 am
Hi, its me again.
I saw some other thing with the QuickTableFilterField:
If its disabled, the filterbutton can still be pressed, means the popup-menu does apear. Does this make sens? If yes, it would be nice if there is or will be a way do disable it. Thanks
orome
Postby JIDE Support » Wed Feb 08, 2006 9:13 am
Good catch. I'll fix it.
Postby JIDE Support » Mon Mar 06, 2006 12:12 am
Just so you know, we fixed this bug in 1.9.0 version we just released.
Postby orome » Mon Mar 06, 2006 12:32 am
Good to Know, ill get a look at it asap, thanks
orome
Users browsing this forum: No registered users and 44 guests
