Collapsible Pane Button Orientation
Postby cerent » Mon Dec 26, 2016 11:11 pm
I was wondering if it is possible to move the collapse button of the collapsible pane from the left side of the pane to the right side while keeping the EAST sliding direction.
cerent
Re: Collapsible Pane Button Orientation
Postby JIDE Support » Fri Dec 30, 2016 3:50 pm
It was not supported right now. It should be possible to add but I felt it is strange to be the other direction. Any reason for that?
Users browsing this forum: No registered users and 98 guests
