Correct JIDE Grids Developer Guide
Postby hfontanez » Thu Mar 31, 2016 9:38 am
I am not sure if this is the right forum to report this, but I believe I discover a minor issue with the aforementioned document. On page 8, there is code snippet to show how headers are created and set in a JIDE Table. The second to last line is incorrect, in my opinion. The line:
NestedTableHeader header = (NestedTableHeader) table.getTableHeader();
header.addColumnGroup(all);
doesn't work because a table doesn't have a default table header. Therefore, it returns null. I was trying this example, and I had to create my own header and add it to the table.
NestedTableHeader header = new NestedTableHeader(table);
Maybe I did something wrong when creating the JIDE Table, but I highly doubt it. This might be trivial for many, but for many inexperienced developers, this might be a difficult thing to overcome. I also think that examples should be more complete. In this case, the snippet should include the creation of the table itself.
hfontanez
Re: Correct JIDE Grids Developer Guide
Postby JIDE Support » Thu Mar 31, 2016 9:55 am
This code is after the NestedTableHeader has been set to the table.
