Chart multiple SummingChartModel with multiple YAxis
Postby rzely » Fri Mar 21, 2014 9:52 am
When I show some speed data (limits 0 - 23)
it's showed ok.
Or when I show some direction data (limits 0 - 360)
that's ok too.
But, if I want show both with differents axes
seems like direction (light blue) use speed axis.
If I use DefaultChartModel it work like a charm. But, I have to use SummingChartModel (all charts are using SummingChartModel ) . And I get this error.
Why its not possible on currentversion ?
rzely
Re: Chart multiple SummingChartModel with multiple YAxis
Postby charts.support » Fri May 23, 2014 3:47 am
This could be a bug. As a test, can you try wrapping your SummingChartModel in a TransformingChartModel, but without setting a transform on the model?
i.e., ChartModel m = new TransformingChartModel(summingChartModel);
That way, the data seen by the chart should be the same. Does the chart behave differently or is it still wrong?
JIDE Charts Support
charts.support
Users browsing this forum: No registered users and 182 guests
