Rich Text Editor using TinyMCE
Postby drewformica » Thu Aug 22, 2013 12:07 pm
Has there been any though towards incorporating a Rich Text Editor into your offering? I know you have the Code Editor and have seen posts where you talk about the line that shalln't be crossed with that component. I only ask because we are in need of one and I was surprised to not find one here (when considering all of the other kick@ss components you have). It seems as if TinyMCE (although javascript) is a great LGPL solution. There's a project on source forge "DJ Project" (http://djproject.sourceforge.net/ns/) that has a component JHTMLEditor that appears to wrap TinyMCE in a JEditorPane (I think). I would use it but I'm not sure how active, well maintained it is.
Wow, that was a rambling paragraph. Anyways I know we need a component like that, wasn't sure if your other customers did and if there was any thought or consideration in providing one in the future.
thanks
drew
drewformica
Re: Rich Text Editor using TinyMCE
Postby JIDE Support » Thu Aug 22, 2013 10:18 pm
Thanks for the suggestion. We thought about it quite a while ago (probably because people asked) but decided not to do it as the effort seems HUGE unless we go for the "wrapping" way as DJ does. I think for now we probably won't do it unless a company are willing to sponsor part of the effort.
Postby seasiainfotech » Thu Jul 31, 2014 10:43 pm
It might also helps in editing rich text within web browsers, which presents the user with a "what-you-see-is-what-you-get" (WYSIWYG) editing area. The aim is to reduce the effort for users trying to express their formatting directly as valid HTML markup...
seasiainfotech
Users browsing this forum: No registered users and 178 guests
