expanding TreeComboBox
Postby nicola.gioia » Mon Dec 05, 2005 10:25 am
when I exec a setSelectedItem(Object e) on a TreeComboBox
the combo box will always expand. It is possible to select a level in a tree in the TreeComboBox without expand the combobox?
nicola.gioia
Postby JIDE Support » Mon Dec 05, 2005 11:29 am
I wonder why I can't reproduce it in ComboBoxDemo. Are you on latest jide 1.8.5.02?
Postby nicola.gioia » Tue Dec 06, 2005 5:07 am
I have found the problem:
i need to override the method setSelectedItem(Object e) that in his body call the method this.getTree() which cause the showing of the popup
The code example needed to reproduce the problem is:
import java.awt.event.*;
import javax.swing.tree.DefaultMutableTreeNode;
import com.jidesoft.combobox.TreeComboBox;
public class TreeComboExample extends JFrame{
   protected TreeComboBox tcb;
   JTree tree;
   public TreeComboExample() {
      init();
   protected void init() {
      this.setContentPane(new JPanel(new BorderLayout()));
      this.setSize(new Dimension(150,60));
      this.setDefaultCloseOperation(JDialog.EXIT_ON_CLOSE);
      tree = new JTree();
      this.tcb = new TreeComboBox(tree.getModel());
      this.getContentPane().add(this.tcb,BorderLayout.CENTER);
      JButton b = new JButton("select");
      b.addActionListener(new ActionListener() {
            tcb.setSelectedItem(tree.getModel().getChild(((DefaultMutableTreeNode)tree.getModel().getRoot()).getChildAt(2),2));
            tcb.getTree();
      this.getContentPane().add(b,BorderLayout.WEST);
In this code I have inserted the getTree() in action of button instead that in the overrided method, but the effect is the same.
my version of JIde is 1.8.5 but i don't know which build.
nicola.gioia
Postby JIDE Support » Tue Dec 06, 2005 9:21 am
getTree() will show the popup. The reason is the tree is not created until popup is shown. Since you ask for the tree, we have to show popup first then return you the tree instance.
Users browsing this forum: No registered users and 33 guests
