Scala and Groovy support on the CodeEditorComponent
Postby dmostert » Thu Feb 14, 2013 10:04 am
Are you guys planning support for Scala and Groovy in the CodeEditorComponent?
dmostert
Re: Scala and Groovy support on the CodeEditorComponent
Postby JIDE Support » Thu Feb 14, 2013 10:16 am
We don't plan to support it out of box but it is just a matter of a customized token marker. Please feel free to create a token marker yourself and set it to CodeEditor. That''ll give you the syntax color feature. If you would like to contribute back to us, that'll be even great. I can send you the source code of an existing token marker if you decide to start from there.
Postby dmostert » Fri Feb 15, 2013 1:14 am
Yes, please, that will be great. You can email it to divan.mostert @ c24.biz.
dmostert
Postby salamander » Mon Apr 14, 2014 10:29 pm
Hello There,
we would need a GroovyTokenMarker too. Are there any news or is it possible to get the sourcecode too?
Kind regards
salamander
Postby JIDE Support » Mon Apr 14, 2014 10:44 pm
We are using the same TokenMarker at http://syntax.jedit.org/. You can download the source code from there.
Users browsing this forum: No registered users and 101 guests
