Add column resize option to column chooser dialog
Postby fredatwork » Mon Sep 10, 2012 5:54 am
In the JIDE demo "Resize Table Demo", you should how to show/hide columns and there is also the option to resize all columns.
Could you plan to add in this dialog the ability to enter column width? (like in Windows Explorer in the "Choose Details" dialog shown when you right click on the table header and select "More..."). Also if this dialog can be triggered programmatically it would help in making the all features accessible.
thanks,
-fred
fredatwork
Re: Add column resize option to column chooser dialog
Postby JIDE Support » Mon Sep 10, 2012 2:29 pm
Thanks for your comments. However, it's hard to find a UI design for such a feature that could satisfy everybody. Also it's hard to say it's a common feature for all table users. I would recommend you design the dialog on your end and add the menu item to pop up the dialog by overriding TableColumnChooserPopupMenuCustomizer#customizePopupMenu().
