Export Jide Tables to HTML
Postby eloy » Sun Sep 09, 2012 11:38 am
I have been asked to export data - which is available in a Jide Grid - to HTML.
Technically, this is no problem but I thought it would be much better
if Jide provides such a feature already out-of-the-box.
I have seen a similar request from another Jide customer:
http://www.jidesoft.com/forum/viewtopic.php?f=17&t=13654&p=67266&hilit=Export#p67266
If I got it right he has also implemented his own solution.
Are there any plans to provide such a feature in an upcoming Jide version?
eloy
eloy
Re: Export Jide Tables to HTML
Postby JIDE Support » Mon Sep 10, 2012 3:06 pm
Yes, it's in our plan and we will keep you posted when we have this feature delivered.
Postby gtt » Thu Apr 07, 2016 4:40 am
Hi all,
we GTT are also urgently interested in exporting to html format as is possible by CSV or HSSF/Excel formats.
What about a release time?
This thread is already some years old.
Regards
Markus (GTT)
gtt
Postby JIDE Support » Thu Apr 07, 2016 9:39 am
We haven't done anything to it. Feel free to do it yourself as it doesn't really have any dependent to the existing JIDE code. I can share the CsvTableUtils here in case you think it might be useful.
Postby gtt » Fri Apr 08, 2016 10:33 am
Yes please share this code ...
gtt
Postby JIDE Support » Fri Apr 08, 2016 11:02 am
I just emailed you the file.
Postby skywalker » Tue Dec 04, 2018 8:40 am
Can you please email me the code of CsvTableUtils as well?
Sanjiv
Edit : got it, thanks
skywalker
Postby skywalker » Wed Mar 13, 2019 5:44 am
I see that CsvTableUtils doesn't support exporting AggregateTablePane. I'd expect the export to be similar to an AggregateTable with aggregate columns. I see there are API's to export AggregateTablePane to Excel but we're unable to use it as we're on an older version of POI that's not compatible with the one Jide requires.
Are you able to add support for exporting AggregateTablePane to CSV? Or if you can give me suggestions on how to implement it similar to what HssfAggregateTablePaneUtils does?
Sanjiv
skywalker
Postby JIDE Support » Wed Mar 13, 2019 10:19 am
HssfAggregateTablePaneUtils just gets each child tables and export them at the right location to create a large table.
Postby skywalker » Wed Mar 13, 2019 10:28 am
(Sorry for the cross post. I intended to delete this one and leave the one under Pivot Grid forum. Since you replied here, I deleted the other dup post).
Are you able to share the source for the relevant portions in HssfAggregateTablePaneUtils so that I can port it to CsvTableUtils with less effort implementing the logic myself?
Sanjiv
skywalker
Postby JIDE Support » Wed Mar 13, 2019 12:32 pm
The main method in HssfAggregateTablePaneUtils is this.
    private static void exportToWorkbook(Workbook wb, String sheetName, AggregateTablePane tablePane, HssfTableFormat format) {
        boolean sheetExists = wb.getSheet(sheetName) != null;
        Sheet sheet = sheetExists ? wb.getSheet(sheetName) : wb.createSheet(sheetName);
        int startColumn = format.getStartColumn();
        int startRow = format.getStartRow();
        int freezeColumn = startColumn;
        JTable rowHeaderTable = tablePane.getRowHeaderTable();
        if (rowHeaderTable != null && rowHeaderTable.getColumnCount() > 0 && rowHeaderTable instanceof AggregateTable) {
            HssfAggregateTableUtils.exportToSheet((AggregateTable) rowHeaderTable, wb, sheet, 0, startColumn, true, format.getCellValueConverter());
            startColumn += rowHeaderTable.getColumnCount();
        JTable mainTable = tablePane.getMainTable();
        if (mainTable != null && mainTable.getColumnCount() != 0) {
            HssfTableUtils.exportToSheet(mainTable, wb, sheet, 0, startColumn, true, format.getCellValueConverter());
            startColumn += mainTable.getColumnCount();
            startRow += mainTable.getRowCount();
        JTable footerTable = tablePane.getRowFooterTable();
        if (footerTable != null && footerTable.getColumnCount() > 0) {
            HssfTableUtils.exportToSheet(footerTable, wb, sheet, 0, startColumn, true, format.getCellValueConverter());
        startColumn = 0;
        JTable rowHeaderColumnFooterTable = tablePane.getRowHeaderColumnFooterTable();
        if (rowHeaderColumnFooterTable != null && rowHeaderColumnFooterTable.getColumnCount() > 0) {
            HssfTableUtils.exportToSheet(rowHeaderColumnFooterTable, wb, sheet, startRow, startColumn, false, format.getCellValueConverter());
            startColumn += rowHeaderColumnFooterTable.getColumnCount();
        JTable columnFooterTable = tablePane.getColumnFooterTable();
        if (columnFooterTable != null && columnFooterTable.getColumnCount() > 0) {
            HssfTableUtils.exportToSheet(columnFooterTable, wb, sheet, startRow, startColumn, false, format.getCellValueConverter());
            startColumn += columnFooterTable.getColumnCount();
        JTable rowFooterColumnFooterTable = tablePane.getRowFooterColumnFooterTable();
        if (rowFooterColumnFooterTable != null && rowFooterColumnFooterTable.getColumnCount() > 0) {
            HssfTableUtils.exportToSheet(rowFooterColumnFooterTable, wb, sheet, startRow, startColumn, false, format.getCellValueConverter());
        if (format.isFreezePanes()) {
            sheet.createFreezePane(freezeColumn, format.getStartRow() + 1);
Postby skywalker » Wed Mar 13, 2019 12:43 pm
Thanks, appreciate it!
skywalker
