DockableFrame popupMenu
Postby nicola.gioia » Thu Nov 03, 2005 3:13 am
It's possible to personalize the popupMenu that appear on right click on the title bar of the DockableFrame to add new function?
I need to add a new functionality "alwais on top" enabled only when the component is in "floating" state.
Alternatively it is possible to use a menuBar that is visible only on "floating" state?
nicola.gioia
Postby JIDE Support » Thu Nov 03, 2005 9:20 am
The popup menu can be customized using dockingManager.setPopupMenuCustomizer(...). All the information you need will be in the parameters that are passed in. See below.
customizePopupMenu(JPopupMenu menu, DockingManager dockingManager, DockableFrame dockableFrame, boolean onTab)
