CheckBoxTree could be made more versatile very easily
Postby jacob » Tue Jul 17, 2012 8:58 am
The checkboxes are declared as type CheckBox in CheckBoxListCellRenderer, which is the obvious choice. However, they could just as easily be abstracted to JToggleButton or JAbstractButton. The major benefit of it being a JToggleButton is that this would allow using a radio button pretty easily via subclassing. Seems like a fairly common use case, I'm currently jumping through hoops to make it happen. I know this is a minor thing, but it would be very trivial to change and I can't see any downside.
jacob
Re: CheckBoxTree could be made more versatile very easily
Postby JIDE Support » Tue Jul 17, 2012 9:07 am
Will change the declaration of the field _checkBox to AbstractButton in next regular release. It will cause backward compatibility issue if some of our customers override this class and call some JCheckBox only methods for that field.
Postby JIDE Support » Tue Jul 24, 2012 4:03 pm
Just so you know, this is fixed in 3.4.4 just released.
Postby jacob » Fri Jul 27, 2012 12:42 pm
Awesome! Thanks for the quick response, this helps me out a bunch.
jacob
