Index out of Bound Exception
Postby rathinamsm » Thu Jun 28, 2012 2:34 am
I'm using Jide 3.4.2 evaluation and in docking when try to float the window in the next to the tab header using mouse double click i got the exception.
Exception in thread "AWT-EventQueue-0" java.lang.ArrayIndexOutOfBoundsException: -1
at java.util.Vector.elementAt(Unknown Source)
at javax.swing.JTabbedPane.getComponentAt(Unknown Source)
at com.jidesoft.docking.FrameContainer.getFrame(Unknown Source)
at com.jidesoft.docking.FrameContainer.isEnabledAt(Unknown Source)
at com.jidesoft.docking.i.mouseClicked(Unknown Source)
at java.awt.AWTEventMulticaster.mouseClicked(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
But this not happened in older versions.
Thanks...
rathinamsm
Re: Index out of Bound Exception
Postby JIDE Support » Thu Jun 28, 2012 9:54 am
Thanks for the bug report. Will fix it in next regular release.
Postby JIDE Support » Thu Jun 28, 2012 12:59 pm
Just so you know, this is fixed in 3.4.3 just released.
