QuickFileterFiled
QuickFileterFiled
Postby vanitha » Mon May 28, 2012 12:36 am
QuickFilterField is really wonderfull, but there should be some provision to return the Original index of the row after filter had happened, For Example, We have below data in the table
ABC
ADE
AAA
AAG
we have typed AA in filter Filed then the table will display below items
AAA
AAG
When you select the row AAA( if we want to perform some operations on this row)... now we are unable to do so as if we select row AAA by table.getSelectedRow() it will actual returning ABC as ABC is first row of actual table.
vanitha
Re: QuickFileterFiled
Postby JIDE Support » Mon May 28, 2012 8:48 am
The table.getSelectedRow() method is a method on JTable thus is considered a view-level method so it should return a row index as you see (from the view). To get the actual row index, using TableModelWrapperUtils.getActualRowAt(table.getModel(), table.getSelectedRow()) which will do the view to model conversion for you.
