DuaList SelectedList wont work properly if we sort the items
Postby vanitha » Thu May 03, 2012 2:18 am
IF we use a DualList and select some items, Then after if we sort the items in the List(means sort the items in the listModel) then the selectedList pane wont show what we selected previously . we have to select selctionMode as REMOVE_SELECTION
For example DualList contains below items
1. Border
2.Apple
3. Cat
4.Dog
we have selected as below
OriginalList selected List
Border Apple
Cat
Daog
After we sort the List the OriginalList and selected List Looks Like below
Apple Border
Cat
Dog
It will be great help the List API has provision to show the selected items as it is after sorting also, means getting the original index after sorting
vanitha
Re: DuaList SelectedList wont work properly if we sort the i
Postby JIDE Support » Thu May 03, 2012 10:10 am
May I ask how you add sorting feature inside the selected list? That will help us try to reproduce the issue on our end. A code fraction would help.
Postby vanitha » Thu May 03, 2012 11:04 pm
Here is my Code I have a testclass contains a dualLIst and a button to sort elemnts of duallist. I have a duallist model which containd arrayList of Elements
import java.awt.BorderLayout;
import java.util.Collections;
import javax.swing.JButton;
import javax.swing.JDialog;
import com.jidesoft.list.DualList;
import com.jidesoft.swing.JideTitledBorder;
import com.jidesoft.swing.PartialEtchedBorder;
import com.jidesoft.swing.PartialSide;
public class TestDualList extends JDialog {
private DualList dualList;
private DualListModel dualListModel;
private JButton sort;
public TestDualList(){
   init();
   buildDialog();
private void buildDialog() {
   add(dualList,BorderLayout.CENTER);
   add(sort,BorderLayout.SOUTH);
   setSize(200,200);
   setVisible(true);
private void init() {
dualListModel=new DualListModel();
dualListModel.updateModel();
 dualList=new DualList(dualListModel);
 dualList.setSelectionMode(DualListModel.REMOVE_SELECTION);
 dualList.setAllowDuplicates(false);
 dualList.getOriginalListPane().setBorder(
         new JideTitledBorder(new PartialEtchedBorder(
               PartialEtchedBorder.LOWERED, PartialSide.NORTH),
               "Available FIX Tags"));
 dualList.getSelectedListPane().setBorder(
               "Selected FIX Tags"));
   // Make all the button invisible exceptt move right and left
 dualList.setButtonVisible(DualList.COMMAND_MOVE_UP, false);
 dualList.setButtonVisible(DualList.COMMAND_MOVE_DOWN, false);
 dualList.setButtonVisible(DualList.COMMAND_MOVE_ALL_LEFT, false);
 dualList.setButtonVisible(DualList.COMMAND_MOVE_ALL_RIGHT, false);
 dualList.setButtonVisible(DualList.COMMAND_MOVE_TO_BOTTOM, false);
 dualList.setButtonVisible(DualList.COMMAND_MOVE_TO_TOP, false);
 sort=new JButton("Sort");
 sort.addActionListener(new ActionListener() {
   public void actionPerformed(ActionEvent arg0) {
      dualListModel.sortByName();
public static void main(String args[]){
   TestDualList list=new TestDualList();
Model class
import java.util.ArrayList;
import com.jidesoft.list.AbstractDualListModel;
public class DualListModel extends AbstractDualListModel {
   ArrayList<String> testElemnts = new ArrayList<String>();
   public Object getElementAt(int index) {
      return testElemnts.get(index);
   public int getSize() {
      return testElemnts.size();
   public void sortByName() {
      Collections.sort(testElemnts);
      fireContentsChanged(this, 0, testElemnts.size());
   public void updateModel(){
      testElemnts.add("Ball");
      testElemnts.add("Apple");
      testElemnts.add("Cat");
      testElemnts.add("Dog");
      testElemnts.add("COW");
Testcase is like below
1) select ball from original list so that selected list contains ball
2) click on sort button
3) Now you will see Apple in the selected list(This happend because previously ball is in the index one and after sorting apple cames to index one)
vanitha
Postby JIDE Support » Fri May 04, 2012 10:56 am
If you sort the entire DualListModel, the model does not have any clue how it should change the selected index. After all, there is no row identifier concept that could help a model to identifies the rows.
You could give the modified test case a try to sort the selected list only. A SortableListModel is installed to help the sorting feature.
TestDualList.java
(2.83 KiB) Downloaded 3488 times
