Add Internationalised support to SortableTable
Postby arazvi » Fri Oct 21, 2005 1:43 am
Can you provide an overloaded SortableTable constructor that accepts a collator to provide language specific sorting, please ? This is one of the requirements holding up the purchase of the JideSoft suite by our company.
For example,
public SortableTable(TableModel tm, Collator c)
which could then be used like this:
TableModel t = new MyTableModel();
Collator c = Collator.getInstance(Locale.FRANCE);
SortableTable s = new Sortable(t, c);
regards, Asad.
arazvi
Postby JIDE Support » Fri Oct 21, 2005 8:16 am
Right now we use Comparator to do the compaision. All default comparators are defined in ObjectComparatorManager. You can also register your own comparator include Collator. The ObjectComparatorManager can be looked up by the type and a context. TableModel can provide them by getColumnClass() and getColumnComparatorContext() (SortableTableModel only) respectively. Would this be good enough for you? If you can think of anything that can make the use of Collator even easier, I would like to add it too.
Postby JIDE Support » Tue Oct 25, 2005 10:20 pm
I didn't see reponse from you. Does my suggest work or you need more help from us?
Postby arooaroo » Sun Sep 10, 2006 6:25 pm
JIDE Support wrote:Right now we use Comparator to do the compaision. All default comparators are defined in ObjectComparatorManager. You can also register your own comparator include Collator. The ObjectComparatorManager can be looked up by the type and a context. TableModel can provide them by getColumnClass() and getColumnComparatorContext() (SortableTableModel only) respectively. Would this be good enough for you? If you can think of anything that can make the use of Collator even easier, I would like to add it too.
I too require the use of Collators for the sort order. Whilst I'm happy that you suggest that we can use our own comparators, I found your reply too difficult too follow.
Is it possible to give a slightly expanded version? Some pseudo-code, perhaps, in order to aid my understaninding of the proposed solution.
Many thanks
arooaroo
Postby JIDE Support » Sun Sep 10, 2006 7:23 pm
Here are the steps.
1. Register the comparators.
ObjectComparatorManager.initDefaultComparator();
ObjectComparatorManager.registerComparator(String.class, new MyComparator(), new ComparatorContext("MyComparator"));
2. Here is how you define SortableTableModel. Note the two methods.
class MySortableTableModel {
    public class getColumnClass(int index) {
        if(index == the special column index) {
              return String.class;
        else {
    protected ComparatorContext getColumnComparatorContext(int column) {
                return new ComparatorContext("MyComparator"); // better define a constant for it
        else return null;
Postby arooaroo » Tue Sep 12, 2006 6:22 am
Many thanks! This really helps.
arooaroo
Re: Add Internationalised support to SortableTable
Postby suar » Thu Feb 23, 2012 9:00 am
I face the same problem. I need to add collator sorting to my SortableTable. I created MySortableTableModel class, which extends SortableTableModel, but mySortableTable.getModel() returns instance of SortableTableModel and not instance of MySortableTableModel. How can i change mySortableTable.getModel() to return instance of MySortableTableModel?
Thank you
suar
Postby JIDE Support » Thu Feb 23, 2012 10:06 am
Do you create a SortableTable like this?
       SortableTable table = new SortableTable(new MySortableTableModel(model));
If yes, the table.getModel() should return MySortableTableModel instance.
Postby suar » Wed Feb 29, 2012 12:24 am
Thank you, issue solved.
suar
