SortableTable sort probelm
Postby jacky4631 » Wed Dec 21, 2011 2:19 am
I use the version jide.1.9.1.05.
There's a column in the table, the column type is String.
When i click the table column header,the column will displayed in certain sort.
If the column text is more than one character, the sort is right,but if the column text only have one character,as a, the sort will be wrong.
I debuged on my side many times, but haven't found any problmes may affect the column sort.
so I want to look for the jide.1.9.1.05 source code to verify, but i couldn't find the code.
can anyone send the code to me or explain the cause, thanks a lot.
jacky4631
Re: SortableTable sort probelm
Postby JIDE Support » Wed Dec 21, 2011 9:13 am
Can you please share with us a test case to investigate further?
Postby jacky4631 » Wed Dec 21, 2011 6:22 pm
i have upload the test case, this is a jide demo, i only change the content of the table column "Task", please sort this column and verify,tks.
AbstractDemo.java
(9.27 KiB) Downloaded 4354 times
TableScrollPaneDemo.java
(9.2 KiB) Downloaded 4264 times
Demo.java
(1.47 KiB) Downloaded 4417 times
jacky4631
Postby JIDE Support » Wed Dec 21, 2011 7:02 pm
Thanks for your test case. I could reproduce the issue in 1.9.1.05. Looks like in that release, the comparing is case sensitive. I would recommend you upgrade to the latest release to fix the issue. If you are not able to do so, please try to register a Comparator for String.class and invoke SortableTableModel#setColumnComparatorContextProvider() to let the column return the ComparatorContext.
Postby jacky4631 » Wed Dec 21, 2011 7:04 pm
I'm sorry , i think this demo is right. let me upload own code,but it is difficult to separate from the project,maybe will take a few times.
jacky4631
