TableScrollPane Zoom In Zoom Out Feature
Postby gehatg » Fri Dec 02, 2011 3:45 am
Hallo,
This should be not that difficult to do, I have a request to allow the users to zoom in / out to the whole TableScrollPane. Exactly like what is happenning to Excel.
Maybe if you add some methods to TableUtils like.
// where float amount +1.0 is MAX ZOOM IN, -1.0 MAX ZOOM OUT and 0 NO ZOOM???
TableUtil.zoomTable(tableScrollPane, float amount);
You can check out that feature in excel on bottom right corner (see image)
Do you think that we can have it soon??? The only difficulty I see there is with row and columns header fonts that you need to reacalculate their size every time, and this should be transparent from CellStyles, correct?
gehatg
Re: TableScrollPane Zoom In Zoom Out Feature
Postby JIDE Support » Fri Dec 02, 2011 9:29 am
Thanks for your suggestions. Comparing Excel, I believe TableScrollPane misses more features than this zoom one. And, of course Excel is more pricy. JIDE, as an component provider, never expects a plain TableScrollPane could be an alternate of excel indeed. For this specific feature, I don't think we would put it in our default package at this moment. You could develop it on your end by adjusting the cell style and row height dynamically. You would also need add a component in UI to control the zoom in/out behavior.
Postby gehatg » Sun Dec 04, 2011 1:18 am
I will try to implement this by my self and let you know how it goes
gehatg
Postby dougakers » Wed Dec 17, 2014 8:47 am
This was originally brought up several years ago. Has there been any progress? Has anyone implemented an overall zoom in/out capability similar to what is now ubiquitous within many applications (e.g. MS Office suite).
dougakers
Postby JIDE Support » Wed Dec 17, 2014 8:55 am
I am not sure about gehatg, we haven't done anything to it.
Users browsing this forum: No registered users and 96 guests
