Excel 2010 filters
Excel 2010 filters
Postby jdm » Fri Oct 28, 2011 7:53 am
I am looking for a solution to filter a JTable column with multiple values (with one check box per value and a search feature, kind of what excel 2010 is doing). Does Jide Grid support this feature ?
Julien
jdm
Re: Excel 2010 filters
Postby JIDE Support » Fri Oct 28, 2011 9:11 am
Please give JIDE AutoFilterTableHeaderDemo and CustomFilterDemo a try and check which component fits better to your request.
Postby jdm » Fri Oct 28, 2011 9:36 am
Thanks. The CustomFilterDemo is hard to understand for people not used to boolean logic.
AutoFilterTableHeaderDemo is very close to what I am looking for when the 'allow multiple values as filter' is set, except it is missing a search feature (useful when there are many values to filter).
jdm
Postby JIDE Support » Fri Oct 28, 2011 9:57 am
There is a Searchable installed for the CheckBoxListChooserPanel. When you popup the panel, you could type some texts to search in the list.
Postby jdm » Mon Oct 31, 2011 1:13 am
Thanks, I did not see it.
jdm
