Possible bug in PropertyPane
Postby nicola.gioia » Wed Oct 05, 2005 2:53 am
if we create a PropertyPane with th code:
new PropertyPane(table);
a propertyPane will be correctly showed, but if i substitute the previous line with
new PropertyPane(table,PropertyPane.BUTTONS_EXPAND_COLLAPSE);
the property pane will not be showed correctly
nicola.gioia
Postby JIDE Support » Wed Oct 05, 2005 8:17 am
This is a known bug and will be fixed in next patch. For now, just don't use the second visibleButtons parameter.
Postby JIDE Support » Thu Oct 27, 2005 11:31 pm
Just so you know, 1.8.5 release should fix this bug.
