Rerender buttons in table that uses QuickTableFilterField
Postby hardy21 » Mon Oct 03, 2011 11:19 am
I'm having problems rerendering the image buttons inside a table that I filter using QuickTableFilterField. First and second columns contain buttons in each row, that when pressed display data (in another panel) about the third column.
I have a 'Refresh' button that I press to do the refresh of the table data and renderers, but after I click it, there are no buttons anymore. I only see their image file name.
The filters are working fine but I need to have the buttons working fine as well.
Thank you.
hardy21
Re: Rerender buttons in table that uses QuickTableFilterFiel
Postby JIDE Support » Mon Oct 03, 2011 12:25 pm
Please give JIDE HyperlinkCellDemo a try and check if the button idea there could help your case.
