Possible Bug in JideTable
Postby arazvi » Tue Oct 04, 2005 5:03 am
Steps to reproduce
[1] Run the Jide WebStart demo
[2] Select the 'Resizable Table Demo'
[3] Drag the 'Name' column to the left,
so it becomes the first column.
[4] Double-click the right-edge of the
'Symbol' column
The 'Name' column gets re-sized instead
of the 'Symbol' column !!
This bug is probably due to your developer
not calling the JTable method convertRowIndexToModel()
regards, A.
arazvi
Postby JIDE Support » Tue Oct 04, 2005 8:43 am
You are right. I'll fix it. Thanks,
Postby JIDE Support » Thu Oct 27, 2005 11:31 pm
Just so you know, 1.8.5 release should fix this bug.
Users browsing this forum: No registered users and 131 guests
