by CHEM_Eugene » Thu Sep 15, 2011 6:06 am
Hello!
When I select only one column for search by this filter, filter is always searching also by group columns. How I can disable search in grouped columns if I need to search only in exactly one?
CHEM_Eugene
by JIDE Support » Thu Sep 15, 2011 8:21 am
Please try to install FilterableTableModel before you install DefaultGroupTableModel. Please give JIDE GroupTableDemo a look about the implementation idea although that's for AutoFilterTableHeader instead of QuickTableFilterField.
by CHEM_Eugene » Thu Sep 15, 2011 11:23 pm
My current code:
- Code: Select all
QuickTableFilterField quickSearchField = new QuickTableFilterField();
FilterableTableModel filterableTableModel = new FilterableTableModel(treeTableModel);
DefaultGroupTableModel groupTableModel = new DefaultGroupTableModel(filterableTableModel);
quickSearchField.setTableModel(groupTableModel);
And so it works as me mentioned above.
CHEM_Eugene
by JIDE Support » Fri Sep 16, 2011 7:19 am
With your code, DefaultGroupTableModel is installed before FilterableTableModel. Please give the following code a try.
- Code: Select all
quickSearchField.setTableModel(treeTableModel);
DefaultGroupTableModel groupTableModel = new DefaultGroupTableModel(quickSearchField.getDisplayTableModel());
