Cache support for Mysql
Postby Sudha » Mon Aug 22, 2011 4:39 am
Can you provide support for cache in mysql database in DatabaseTable Model.? Currently its showing out of memory exception while we try to load huge records from mysql.
Sudha.
Sudha
Re: Cache support for Mysql
Postby JIDE Support » Mon Aug 22, 2011 12:13 pm
Will put it in our job list and let you know if we have any progress.
Postby eliquious » Fri Mar 09, 2012 10:39 am
Any progress? Perhaps another solution would be to add a constructor to the DatabaseTableModel passing in either a ResultSetTableModel or simply a ResultSet. This would allow the coders to apply the fix for the driver on the MySQL website. Otherwise, we have to wrap the ResultSetTableModel with our own IFilterableTableModel and ISortableTableModel implementations.
Max
eliquious
Postby JIDE Support » Fri Mar 09, 2012 2:22 pm
If this is a solution, please give the following code a try. You could now override DatabaseTableModel#refreshData() to add the cache on your end.
        return new DatabaseTableModel(_connection, "*", "sales") {
            private Statement prepareStatement(String sql) throws SQLException {
                Statement statement = adjustStatement(_statement, sql);
                if (statement == null) {
                    statement = _statement;
                return statement;
            public void refreshData(SortItemSupport sortItemSupport, FilterItemSupport filterItemSupport) throws SQLException {
                String countStatement = createCountStatement(filterItemSupport);
                if (_statement == null) {
                    _statement = createStatement();
                Statement statement = prepareStatement(countStatement);
                ResultSet countRs = statement.executeQuery(countStatement);
                countRs.next();
                int rowCount = countRs.getInt(1);
                StringBuffer s = createSqlStatement(_preStatement, _selectStatement, _fromStatement, sortItemSupport, filterItemSupport);
                String sql = s.toString();
                statement = prepareStatement(sql);
                ResultSet resultSet = statement.executeQuery(sql);
                if (_resultSetTableModel != null) {
                    _resultSetTableModel.close();
                _resultSetTableModel = createResultSetTableModel(resultSet, rowCount);
                configureConverterContexts();
                fireTableDataChanged();
Postby eliquious » Tue Mar 13, 2012 8:54 am
Thanks! That did get me started in the right direction.
Max
eliquious
