Quick Filter for Checkbox Tree
Postby iyerna » Mon May 30, 2011 2:22 am
We found the following bug after we added a quick filter field to the Jide Checkbox Tree. If we select multiple nodes (> 1) & filter for a non-existent item in the tree, the tree selection loses 1 selection for every character typed in the filter text box. This was found in release 2.11.2. Please let us know if this issue can be fixed. Thanks,
iyerna
Re: Quick Filter for Checkbox Tree
Postby JIDE Support » Mon May 30, 2011 5:50 am
Please use FilterableCheckBoxTreeSelectionModel in jide-grids.jar as its selection model to make it have appropriate filtering function.
Postby balago » Mon May 30, 2011 6:26 am
We found the bug while using FilterableCheckBoxTreeSelectionModel from jide-grids
balago
Postby JIDE Support » Mon May 30, 2011 9:52 am
Reproduced. Will fix it in next regular release.
Postby balago » Tue May 31, 2011 10:12 pm
When is the next regular release going to happen?
balago
Postby JIDE Support » Wed Jun 01, 2011 6:07 am
Will release next regular release within this week.
Postby JIDE Support » Thu Jun 09, 2011 5:53 pm
Just so you know, this is fixed in 3.0.4 just released. Sorry for the late.
