Convert column header in HssfTableScrollPaneUtils
Postby orttni » Thu Dec 30, 2010 1:40 am
The HssfTableScrollPaneUtils is a very nifty class to get table data into Excel. However - I lack the possibility to convert column names, i.e. is is the column names from the table model that are used but I'd like to translate them into current user's language before they're xported. I can see that in the super class HssfTableUtils there are some methods where you can specify a "columnNameConverter" which is an instanceof "StringConverter". It would be great if you could add another method to HssfTableScrollPaneUtils to accomplish this, e.g.
public static boolean export(TableScrollPane table,
                             String fileName,
                             String sheetName,
                             boolean append,
                             StringConverter columnNameConverter)
                      throws IOException
This would be exactly what I need. Perhaps there is a way to accomplish this already?
orttni
Re: Convert column header in HssfTableScrollPaneUtils
Postby JIDE Support » Thu Dec 30, 2010 10:59 am
Will do so in 2.10.4.
Postby JIDE Support » Thu Dec 30, 2010 2:28 pm
Just so you know, this new API is added in 2.10.4 just released.
Postby orttni » Mon Jan 10, 2011 12:12 am
Great!
orttni
