AutoFilterTableHeader support for Groupable columns
Postby iyerna » Tue Nov 02, 2010 11:19 pm
We use the AutoFilterTableHeader by default for all our tables. We also have several tables that have nested / groupable columns for which we use the NestedTableHeader.
There is a requirement to support filtering for the tables with nested columns as well. Can these 2 features be integrated in a single table header renderer (NestedAutoFilterTableHeader?).
Ideally, we would only want the filters to be on the leaf column headers. This enhancement is very high on our priority list & would be great if you could add it to your list of enhancements.
Thanks & Regards,
Natarajan Iyer
Tech Architect
Goldman Sachs
iyerna
Re: AutoFilterTableHeader support for Groupable columns
Postby JIDE Support » Wed Nov 03, 2010 11:55 am
We currently have a plan to redesign NestedTableHeader. Will consider your comments if possible. Will keep you posted as long as we have any progress.
Postby iyerna » Tue Nov 16, 2010 6:20 am
Thanks!
iyerna
Postby iyerna » Tue Jan 11, 2011 12:20 am
Any update on the NestedTableHeader enhancement? i.e. are we planning to include this in a near future release? Thanks,
Natarajan
iyerna
Postby JIDE Support » Tue Jan 11, 2011 8:09 am
I'm afraid it will not be a near-term feature. Based on our new year plan, it will happen in 2.13, which may release at the end of 2011.
Postby iyerna » Sun May 29, 2011 11:35 pm
Is this confirmed for release 2.13? Our users have been asking for this. Thanks,
iyerna
Postby JIDE Support » Mon May 30, 2011 6:01 am
We are working on this feature, which will be released within a month.
Postby JIDE Support » Fri Jul 01, 2011 8:25 am
Just so you know, NestedTableHeader now supports auto filter feature in 3.1.0 just released. Please give JIDE JideTableDemo a try.
