AutoFilterTreeTableDemo Issues
Postby jameszhao » Thu Aug 26, 2010 6:58 am
1. For QuickTableFilterField in AutoFilterTreeTableDemo, is it possible to add multi keywords to search the entire table? e.g. keywords delimited by space, like google search.
2. Can filter function be changed to accept "Return only" instead of the current effect? Because the window freezes when the data size is too large.
James
jameszhao
Re: AutoFilterTreeTableDemo Issues
Postby JIDE Support » Thu Aug 26, 2010 8:35 am
1, So far not. You may give LuceneQuickTableFilterField which could accept multiple input. However, you have to deal with the lucene syntax for the request. Or you could try to override QuickTableFilterField#getFilter() to construct your own filter to achieve your goal.
2, Please invoke QuickTableFilterField#setSearchingDelay(-1).
Postby jameszhao » Thu Aug 26, 2010 8:41 am
For 2, can I take AUTO feature function off, only accept RETURN? Because this is normal way to search.
James
jameszhao
Postby JIDE Support » Thu Aug 26, 2010 8:54 am
Please just remove the code so that AutoFilterTableHeader will not get installed in the table.
Users browsing this forum: Baidu [Spider] and 57 guests
