Problems with DateComboBox
Postby gaurang.patel » Tue Aug 10, 2010 7:32 am
1.Presently if we select a date from DateComboBox and then manually change any fild like we change the date field to 32 then the automatically the date of next month is displayed, shouldnt it give an error dat date value is not valid?
2.If the user manually types date in the DateComboBox in the wrong format, the combobox just gets cleared, shouldn't be ther any error??
gaurang.patel
Re: Problems with DateComboBox
Postby JIDE Support » Tue Aug 10, 2010 8:25 am
1, The behavior was inherited from DateFormat#parse() by default. You could try to define your own DateFormat to parse it to return a null value in your DateConverter.
2, DateComboBox has several behaviors on focus lost, including COMMIT, COMMIT_OR_REVERT, REVERT, PERSIST, COMMIT_OR_RESET. We don't recommend to promt to the end user any dialog on wrong inputing. However, if you want, you could override DateComboBox#setSelectedItem() to check if the value is valid then popup a dialog.
