protected void initTable() {
super.initTable();
setSortTableHeaderRenderer();
protected JTableHeader createDefaultTableHeader() {
return new JTableHeader(columnModel);
_sortableTable.getTableHeader().setPreferredSize(new Dimension(_sortableTable.getTableHeader().getPreferredSize().width, 40));
* @(#)SortableTableDemo.java
* Copyright 2002 - 2003 JIDE Software Inc. All rights reserved.
import com.jidesoft.converter.ConverterContext;
import com.jidesoft.converter.DoubleConverter;
import com.jidesoft.converter.ObjectConverterManager;
import com.jidesoft.grid.*;
import com.jidesoft.hssf.HssfTableUtils;
import com.jidesoft.icons.JideIconsFactory;
import com.jidesoft.swing.JideBoxLayout;
import com.jidesoft.swing.JideTabbedPane;
import javax.swing.table.AbstractTableModel;
import javax.swing.table.TableModel;
import java.io.File;
import java.io.IOException;
import java.text.DecimalFormat;
import java.util.Calendar;
import java.util.Date;
* Demoed Component: {@link SortableTable} <br> Required jar files: jide-common.jar, jide-grids.jar <br> Required L&F:
* any L&F
public class SortableTableDemo extends AbstractDemo {
protected SortableTable _sortableTable;
protected String _lastDirectory = ".";
private static final long serialVersionUID = -5373007282200581748L;
public SortableTableDemo() {
ObjectConverterManager.initDefaultConverter();
DecimalFormat format = new DecimalFormat();
format.setMinimumFractionDigits(2);
format.setMaximumFractionDigits(10);
DoubleConverter converter = new DoubleConverter(format);
ObjectConverterManager.registerConverter(Double.class, converter);
public String getName() {
return "SortableTable Demo";
public String getProduct() {
return PRODUCT_NAME_GRIDS;
public int getAttributes() {
return Demo.ATTRIBUTE_UPDATED;
return "This is a demo of SortableTable. \n" +
"\nClick once on the header to sort ascending, click twice to sort descending, a third time to unsort. Hold CTRL key (or Command key on Mac OS X) then click on several headers to see mulitple columns sorting.\n" +
"\n" +
"Demoed classes:\n" +
"com.jidesoft.grid.SortableTable";
JPanel panel = new JPanel();
panel.setLayout(new JideBoxLayout(panel, JideBoxLayout.Y_AXIS));
panel.add(new JLabel("Maximum sorted columns: "));
DefaultComboBoxModel model = new DefaultComboBoxModel();
model.addElement("No maximum (default)");
for (int i = 0; i < _sortableTable.getColumnCount(); i++) {
model.addElement(new Integer(i + 1));
panel.add(Box.createVerticalStrut(3));
final JComboBox maxComboBox = new JComboBox(model);
maxComboBox.addActionListener(new AbstractAction() {
private static final long serialVersionUID = -6480174819379988040L;
int maxCount = maxComboBox.getSelectedIndex();
if (maxCount == 0) {
((ISortableTableModel) _sortableTable.getModel()).setMaximumSortColumns(-1);
else {
((ISortableTableModel) _sortableTable.getModel()).setMaximumSortColumns(maxCount);
panel.add(maxComboBox);
panel.add(Box.createVerticalStrut(6));
panel.add(new JLabel("Sort priority: "));
model.addElement("FILO (Default)");
model.addElement("FIFO");
final JComboBox priorityComboBox = new JComboBox(model);
priorityComboBox.addActionListener(new AbstractAction() {
private static final long serialVersionUID = 3712678830602409607L;
int priority = priorityComboBox.getSelectedIndex();
((ISortableTableModel) _sortableTable.getModel()).setSortPriority(priority);
panel.add(priorityComboBox);
panel.add(Box.createVerticalStrut(12));
JCheckBox sortingEnabled = new JCheckBox("Allow user to sort table");
sortingEnabled.setSelected(_sortableTable.isSortingEnabled());
sortingEnabled.addItemListener(new ItemListener() {
_sortableTable.setSortingEnabled(e.getStateChange() == ItemEvent.SELECTED);
panel.add(sortingEnabled);
JCheckBox showSortOrder = new JCheckBox("Always show sort order");
showSortOrder.setSelected(_sortableTable.isShowSortOrderNumber());
showSortOrder.addItemListener(new ItemListener() {
_sortableTable.setShowSortOrderNumber(e.getStateChange() == ItemEvent.SELECTED);
panel.add(showSortOrder);
final JCheckBox sortIconCheckBox = new JCheckBox("Use Look&Feel Default Sort Icon");
sortIconCheckBox.addItemListener(new ItemListener() {
_sortableTable.setUseLnfDefaultSortIcon(e.getStateChange() == ItemEvent.SELECTED);
sortIconCheckBox.setSelected(_sortableTable.isUseLnfDefaultSortIcon());
panel.add(sortIconCheckBox);
panel.add(new JButton(new AbstractAction("Export to Excel") {
private static final long serialVersionUID = -3816637828684822007L;
if (!HssfTableUtils.isHssfInstalled()) {
JOptionPane.showMessageDialog((Component) e.getSource(), "Export to Excel feature is disabled in the webstart demo because hssf.jar is not in the classpath.");
return;
JFileChooser chooser = new JFileChooser() {
protected JDialog createDialog(Component parent) throws HeadlessException {
JDialog dialog = super.createDialog(parent);
dialog.setTitle("Export the content to an \".xls\" file");
return dialog;
chooser.setCurrentDirectory(new File(_lastDirectory));
int result = chooser.showDialog(((JButton) e.getSource()).getTopLevelAncestor(), "Export");
if (result == JFileChooser.APPROVE_OPTION) {
_lastDirectory = chooser.getCurrentDirectory().getAbsolutePath();
HssfTableUtils.export(_sortableTable, chooser.getSelectedFile().getAbsolutePath(), "SortableTable", false, true, new HssfTableUtils.DefaultCellValueConverter() {
public int getDataFormat(JTable table, Object value, int rowIndex, int columnIndex) {
if (value instanceof Double) {
return 2; // use 0.00 format
else if (value instanceof Date) {
return 0xe; // use "m/d/yy" format
return super.getDataFormat(table, value, rowIndex, columnIndex);
catch (IOException e1) {
e1.printStackTrace();
return panel;
TableModel model = new SampleTableModel();
_sortableTable = new SortableTable(model);
AutoFilterTableHeader header = new AutoFilterTableHeader(_sortableTable);
header.setAutoFilterEnabled(true);
_sortableTable.setTableHeader(header);
JTable normalTable = new JTable(model);
JideTabbedPane tabbedPane = new JideTabbedPane();
tabbedPane.setTabShape(JideTabbedPane.SHAPE_BOX);
tabbedPane.addTab("SortableTable", new JScrollPane(_sortableTable));
tabbedPane.addTab("JTable (for comparison)", new JScrollPane(normalTable));
tabbedPane.setPreferredSize(new Dimension(550, 400));
return tabbedPane;
static class SampleTableModel extends AbstractTableModel implements ContextSensitiveTableModel, ToolTipSupport {
private static final long serialVersionUID = 8798261997256893224L;
public int getColumnCount() {
return 6;
public int getRowCount() {
return 8;
public boolean isCellEditable(int rowIndex, int columnIndex) {
public ConverterContext getConverterContextAt(int row, int column) {
return null;
public EditorContext getEditorContextAt(int row, int column) {
return null;
public Class<?> getCellClassAt(int row, int column) {
return getColumnClass(column);
public String getColumnName(int column) {
switch (column) {
case 0:
return "int column";
case 1:
return "<html>double<br>column</html>";
case 2:
return "boolean column";
case 3:
return "string column";
case 4:
return "icon column";
case 5:
return "date column";
return "";
public Class<?> getColumnClass(int column) {
switch (column) {
case 0:
return Integer.class;
case 1:
return Double.class;
case 2:
return Boolean.class;
case 3:
return String.class;
case 4:
return Icon.class;
case 5:
return Date.class;
return Object.class;
public Object getValueAt(int row, int column) {
switch (column) {
case 0:
if (row > 4) {
return 2;
else {
return row;
case 1:
return row * 2.333333;
case 2:
if (row % 2 == 0)
return Boolean.TRUE;
return Boolean.FALSE;
case 3:
return "row " + (getRowCount() - row);
case 4:
if (row % 2 == 0)
return JideIconsFactory.getImageIcon(JideIconsFactory.FileType.HTML);
else
return JideIconsFactory.getImageIcon(JideIconsFactory.FileType.JAVA);
case 5:
Calendar calendar = Calendar.getInstance();
calendar.roll(Calendar.DAY_OF_YEAR, row);
return calendar.getTime();
return null;
public String getToolTipText(int columnIndex) {
return "Click to sort this " + getColumnName(columnIndex);
return "G2.SortableTable";
showAsFrame(new SortableTableDemo());
import javax.swing.Icon;
import javax.swing.JTable;
import java.util.Comparator;
import com.jidesoft.grid.AutoFilterBox;
import com.jidesoft.grid.AutoFilterTableHeader;
import com.jidesoft.grid.FilterableTableModel;
import com.jidesoft.grid.FilterableTableModelEvent;
import com.jidesoft.grid.FilterableTreeTableModel;
import com.jidesoft.grid.IFilterableTableModel;
import com.jidesoft.grid.SortableTable;
import com.jidesoft.grid.TreeTable;
public class CNAutoFilterTableHeader extends AutoFilterTableHeader
private JTable _table = null;
private CNTablePanel _nTable = null;
public CNAutoFilterTableHeader(CNTablePanel nTable)
super(nTable.getTable());
_table = nTable.getTable();
_nTable = nTable;
protected IFilterableTableModel createFilterableTableModel(TableModel model) {
if (_table instanceof TreeTable)
return new FilterableTableModel(model) {
public boolean isColumnAutoFilterable(int column) {
return true;
public Object[] getPossibleValues(int column, Comparator comparator) {
return super.getPossibleValues(column, new Comparator(){
public int compare(Object firstObj, Object secondObj) {
if (firstObj instanceof Comparable && secondObj instanceof Comparable)
return ((Comparable)firstObj).compareTo(secondObj);
else {
String str1 = firstObj.toString();
String str2 = secondObj.toString();
return (str1.compareToIgnoreCase(str2));
} catch (Exception e) {
e.printStackTrace();
return -1;
protected boolean shouldPossibleValueBeIncluded(Object value,int columnIndex)
if (value == null)
return !(value.toString().equals(""));
else
return new FilterableTreeTableModel(model) {
return true;
else {
return -1;
if (value == null)
if (value instanceof JobStatus )
String str = ((JobStatus)value).toString();
if (str.equals(StringBank.UNKNOWN))
else
return!(str.equals(""));
public void filterableTableModelChanged(FilterableTableModelEvent event)
super.filterableTableModelChanged(event);
_nTable.setPreferredWidthOfColumns();
protected void customizeAutoFilterBox(AutoFilterBox autoFilterBox) {
autoFilterBox.setBackground(Utilities.COLOR_LIGHT_LIGHT_GREY);
if (autoFilterBox.getFilterTitleFormatter() ==null) {
autoFilterBox.setFilterTitleFormatter(new Formatter());
super.customizeAutoFilterBox(autoFilterBox);
autoFilterBox.setShowFilterName(true);
protected Icon createSortIcon(SortableTable table, boolean ascending)
if (ascending)
return RuntimeContext.upIcon;
else
return RuntimeContext.downIcon;
class Formatter implements AutoFilterBox.FilterTitleFormatter
String filter = "";
public String formatColumnTitle(String columnName, com.jidesoft.filter.Filter[] filters) {
filter = "";
if (filters !=null && filters.length > 0)
if ( filters[0].getName().equals("All") == false)
filter = ":" + filters[0].getName();
// System.out.println("formatColumnTitle:: " + columnName + ", filter: " + filter);
return "<html><body><b>" + columnName + filter + "</b></body></html>";
public String getFilterName()
return filter;
public void clearFilter()
filter="";
public static class CNTableHeaderRenderer extends DefaultTableCellRenderer
GradientPanel panel = null;
int maxHeight = 0;
int pady = 10;
public CNTableHeaderRenderer(boolean darkHeader)
if (darkHeader)
panel = new GradientPanel(new GridBagLayout(), Utilities.COLOR_GRADIENT1_DARKER, Utilities.COLOR_GRADIENT2, GradientPanel.VERTICAL);
else
panel = new GradientPanel(new GridBagLayout(), Utilities.COLOR_GRADIENT2, GradientPanel.VERTICAL);
public Component getTableCellRendererComponent(JTable table, Object value, boolean isSelected, boolean hasFocus, int row, int column) {
Component actualRenderer = super.getTableCellRendererComponent(table,value,isSelected,hasFocus,row,column);
if (table != null) {
JTableHeader header = table.getTableHeader();
if (header != null) {
actualRenderer.setForeground(header.getForeground());
actualRenderer.setBackground(header.getBackground());
actualRenderer.setFont(header.getFont().deriveFont(Font.BOLD));
Component headerComponent = null;
String stringValue = (value == null) ? "" : value.toString();
GridBagConstraints constraints = new GridBagConstraints();
if (stringValue.indexOf('\n') != -1)
JPanel cellPanel =new JPanel(new GridBagLayout());
cellPanel.setOpaque(false);
String totalString = stringValue;
JLabel tempLabel = null;
int rows =0;
while(totalString.indexOf('\n') != -1)
String partString = totalString.substring(0, totalString.indexOf('\n'));
tempLabel = new JLabel(partString);
tempLabel.setHorizontalAlignment(JLabel.CENTER);
tempLabel.setOpaque(false);
tempLabel.setFont(actualRenderer.getFont());
cellPanel.add(tempLabel, Utilities.getConstraints(constraints, GridBagConstraints.RELATIVE, GridBagConstraints.RELATIVE, GridBagConstraints.REMAINDER, 1, 1, 0, GridBagConstraints.NORTH, GridBagConstraints.HORIZONTAL));
totalString = totalString.substring(totalString.indexOf('\n')+1);
rows++;
tempLabel = new JLabel(totalString );
cellPanel.add(tempLabel, Utilities.getConstraints(constraints, GridBagConstraints.RELATIVE, GridBagConstraints.RELATIVE, GridBagConstraints.REMAINDER, GridBagConstraints.REMAINDER, 1, 1, GridBagConstraints.NORTH, GridBagConstraints.HORIZONTAL, new Insets(0,0,3,0)));
headerComponent = cellPanel;
panel.removeAll();
panel.add(headerComponent, Utilities.getConstraints(constraints,
1,
1,
GridBagConstraints.BOTH,
new Insets(3,3,3,3)));
int h = (tempLabel.getFontMetrics(tempLabel.getFont()).getHeight() + 10) * rows; //headerComponent.getPreferredSize().height ;
if (h > maxHeight)
maxHeight = h;
else
JLabel label = (JLabel) actualRenderer;
label.setText((value == null) ? "" : value.toString() );
label.setHorizontalAlignment(JLabel.CENTER);
label.setVerticalAlignment(JLabel.NORTH);
label.setOpaque(false);
headerComponent = label;
panel.removeAll();
1,
1,
GridBagConstraints.NONE,
int h = headerComponent.getPreferredSize().height ;
if (h > maxHeight)
maxHeight = h;
panel.setPreferredSize(new Dimension((int)headerComponent.getPreferredSize().getWidth() + 30,maxHeight + pady));
return panel;
protected TableCellEditor createDefaultEditor() {
if (isAutoFilterEnabled()) {
return new AutoFilterTableHeaderEditor() {
autoFilterBox.applyComponentOrientation(AutoFilterTableHeader.this.getComponentOrientation());
AutoFilterTableHeader.this.customizeAutoFilterBox(autoFilterBox);
else {
return null;
myTable = new SortableTable(myModel) {
return new MultilineTableHeader(columnModel);
* BUG: Default JTable header renderer does not properly calculate
* preferred height when any of the columns has a multiline column name.
* This is a fix proposed on the sun website.
* http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=4292511
private static class MultilineTableHeader extends SortableTableHeader {
private int preferrredHeight = -1;
public MultilineTableHeader(TableColumnModel cm) {
super(cm);
private Component getHeaderRenderer(int columnIndex) {
TableColumn aColumn = getColumnModel().getColumn(columnIndex);
TableCellRenderer renderer = aColumn.getHeaderRenderer();
if (renderer == null) {
renderer = getDefaultRenderer();
return renderer.getTableCellRendererComponent(getTable(), aColumn.getHeaderValue(), false, false, -1, columnIndex);
private int getPreferredHeight() {
if (preferrredHeight == -1) {
preferrredHeight = 0;
TableColumnModel columnModel = getColumnModel();
for (int column = 0; column < columnModel.getColumnCount(); column++) {
Component comp = getHeaderRenderer(column);
int rendererHeight = comp.getPreferredSize().height;
preferrredHeight = Math.max(preferrredHeight, rendererHeight);
return preferrredHeight;
public Dimension getPreferredSize() {
return new Dimension(super.getPreferredSize().width, getPreferredHeight());
public void columnAdded(TableColumnModelEvent e) {
super.columnAdded(e);
public void columnRemoved(TableColumnModelEvent e) {
super.columnRemoved(e);
}Users browsing this forum: Baidu [Spider] and 92 guests
