Scrolling the the popup sub menu
Postby Skjalg » Tue Jun 15, 2010 6:02 am
Hi there, I was wondering how I could achieve the scrolling behavior in a popup sub menu.
See the attached code for what I mean;
        final JFrame d = new JFrame();
        final JidePopupMenu ppm = new JidePopupMenu();
        for (int j = 1; j < 150; j++) {
            JMenu option = new JMenu("JMenu Option " + j);
            for (int i = 1; i < 150; i++) {
                option.add(new JMenuItem("JMenuItem Option " + i));
            ppm.add(option);
        d.addMouseListener(new MouseAdapter() {
            public void mouseClicked(MouseEvent e) {
                ppm.show(d, e.getX(), e.getY());
        d.setPreferredSize(new Dimension(200, 100));
        d.setVisible(true);
        d.pack();
The list of JMenu Options scrolls perfectly fine, but their submenus does not.
I have tried adding a simple scroll to the popup menu (with all the menuitems) but each time I hover over that menu item the popup disappears....
Skjalg
Re: Scrolling the the popup sub menu
Postby JIDE Support » Tue Jun 15, 2010 9:14 am
It's not easy to override the submenu to have scrollable. Please check out if the code shared by klakotko http://www.jidesoft.com/forum/viewtopic.php?f=10&t=9654 could help your case.
Postby Skjalg » Wed Jun 16, 2010 12:38 am
Thanks a lot, I'm sorry I didn't find that before posting.
Is there any chance you guys can adapt his code and add this functionality as a Jide class?
Skjalg
Postby JIDE Support » Wed Jun 16, 2010 11:37 am
I'm afraid not for now.
Users browsing this forum: No registered users and 73 guests
