Overriding autohide functionality
Postby andrewbrook » Mon Jun 14, 2010 1:40 pm
I was wondering how I would override the autohide functionality of DockableFrames.
By default, mousing over a tab will cause it to show and mousing out will hide it again.
I would like to toggle show/hide by clicking the tab. Mousing over should do nothing.
Andrew
andrewbrook
Re: Overriding autohide functionality
Postby JIDE Support » Mon Jun 14, 2010 1:50 pm
If you don't like the mouse rollover behavior, please try to invoke DefaultDockingManager#setSidebarRollover(false).
Postby andrewbrook » Tue Jun 15, 2010 9:55 am
Thanks for the response.
That works, however, the DockableFrame only shows/hides if the DockingManager that contains it already has focus.
So if another frame has focus and a tab is clicked, the new frame will flicker on and off. Another click to this same tab is require to activate the frame.
Andrew
andrewbrook
Postby JIDE Support » Tue Jun 15, 2010 11:28 am
Would you please give the following test case a try? In this test case, there are two DockingManagers disabling the sidebar rollover flag. Please autohide these two frames after launching the test case. If one DockingManager has focus, I could not notice the flickering while clicking on another autohidden DockableFrame.
TestTest5.java
(3.18 KiB) Downloaded 2230 times
