Issues with Filterable CheckBoxTree
Postby KkOo » Wed May 12, 2010 5:19 am
Hello there,
I am trying to use CheckBoxTree along with QuickTreeFilterField and i am facing little annoying issues.
Say i have this tree :
- Child1
    - sChild11
    - sChild12
    - sChild13
- Child2
    - sChild21
    - sChild22
First issue is:
- check sChild22
- filter the tree by "sChild1"
- check sChild12
- clear the filter
After clearing the field, we can see that we lost the previous check :(
Second issue is:
- filter by "sChild2"
- check Child2
- clear the filter
Again, after clearing, we can see that all the tree got checked :?
It seems that i was able to fix the second problem by overwriting CheckBoxTreeSelectionModel#areSiblingsSelected(TreePath path).
But I dont know how to handle the first one. I tried to pass the original tree model to the constructor of CheckBoxTreeSelectionModel but it doesnt work.
You can see both of theses attempt in the code bellow:
CheckBoxTree tree = new CheckBoxTree((Hashtable) values) {
    protected CheckBoxTreeSelectionModel createCheckBoxTreeSelectionModel(TreeModel model) {
        return new CheckBoxTreeSelectionModel(rawTreeModel) {
            protected boolean areSiblingsSelected(TreePath path) {
                if (filterField.getDisplayTreeModel().isFiltersApplied())
                return super.areSiblingsSelected(path);
rawTreeModel = tree.getModel();
Anyone could advise me ?
Thanks !
KkOo
Re: Issues with Filterable CheckBoxTree
Postby KkOo » Wed May 12, 2010 8:30 am
Sorry for the quick post.
I used the the FilterableCheckBoxTreeSelectionModel instead and the problem 1 gone away.
But the second one is still here...
KkOo
Postby KkOo » Wed May 12, 2010 9:04 am
Dont mind me, If i use the latest version of jide evreything is working correctly :)
Sorry for disturbing you guys
KkOo
Postby JIDE Support » Wed May 12, 2010 10:55 am
I don't really see the problem in a test case we received from another user. It is very similar to what you have.
import java.awt.BorderLayout;
import java.awt.Dimension;
import java.awt.FlowLayout;
import java.util.LinkedHashSet;
import javax.swing.BorderFactory;
import javax.swing.JButton;
import javax.swing.UIManager;
import javax.swing.tree.DefaultMutableTreeNode;
import javax.swing.tree.DefaultTreeModel;
import javax.swing.tree.TreeModel;
import com.jidesoft.dialog.ButtonPanel;
import com.jidesoft.swing.*;
import com.jidesoft.tree.QuickTreeFilterField;
import com.jidesoft.tree.TreeUtils;
import com.jidesoft.tree.FilterableCheckBoxTreeSelectionModel;
public class FilterableCheckBoxTreeSelection extends JFrame {
     * @param args
    private CheckBoxTree _tree;
    private static FilterableCheckBoxTreeSelection theInstance = null;
    private LinkedHashSet<Object> selectedPaths = new LinkedHashSet<Object>();
    public static FilterableCheckBoxTreeSelection getInstance() {
        if (theInstance == null) {
            theInstance = new FilterableCheckBoxTreeSelection();
        return theInstance;
    private FilterableCheckBoxTreeSelection() {
// TODO Auto-generated constructor stub
//        EscapeButtonAction.trap((JComponent) this.getContentPane(), new EscapeButtonAction(this));
        this.setSize(new Dimension(400, 400));
    public JPanel getDemoPanel() {
//JTabbedPane jpane=new JTabbedPane("Graphic");
        JPanel childPanel = new JPanel(new BorderLayout(2, 2));
        JPanel masterPanel = new JPanel(new BorderLayout(6, 6));
//here it will compute and display the data for tree
        _tree = displayTree();
        masterPanel.add(getSearchPanel(), BorderLayout.BEFORE_FIRST_LINE);
        masterPanel.add(getTreePanel());
        masterPanel.add(getButtonPanel(), BorderLayout.PAGE_END);
        childPanel.add(new JPanel(), BorderLayout.BEFORE_LINE_BEGINS);
        childPanel.add(masterPanel, BorderLayout.CENTER);
        childPanel.add(new JPanel(), BorderLayout.AFTER_LINE_ENDS);
        childPanel.add(new JPanel(), BorderLayout.PAGE_END);
// masterPanel.add(new JPanel());
        return childPanel;
    public JPanel getSearchPanel() {
        JPanel quickSearchPanel = new JPanel(new FlowLayout(FlowLayout.LEADING));
        quickSearchPanel.setBorder(new JideTitledBorder(new PartialEtchedBorder(PartialEtchedBorder.LOWERED, PartialSide.NORTH), "Find", JideTitledBorder.LEADING, JideTitledBorder.ABOVE_TOP));
        QuickTreeFilterField filterData = new QuickTreeFilterField(_tree.getModel());
        filterData.setHideEmptyParentNode(true);
        quickSearchPanel.add(filterData);
        _tree = new CheckBoxTree(filterData.getDisplayTreeModel()) {
                return new FilterableCheckBoxTreeSelectionModel(model);
        _tree.setRootVisible(false);
        _tree.setShowsRootHandles(true);
        filterData.setTree(_tree);
        SearchableUtils.installSearchable(_tree);
        TreeUtils.expandAll(_tree, true);
        return quickSearchPanel;
    public JPanel getTreePanel() {
        JPanel treePanel = new JPanel(new BorderLayout(2, 2));
        treePanel.setBorder(BorderFactory.createCompoundBorder(
                        "Value Lever Information", JideTitledBorder.LEADING,
                        JideTitledBorder.ABOVE_TOP), BorderFactory
                .createEmptyBorder(0, 0, 0, 0)));
        treePanel.add(new JScrollPane(_tree));
        return treePanel;
    public JPanel getButtonPanel() {
        JPanel _buttonPanel = new ButtonPanel();
        JButton okButton = new JButton("Ok");
        _buttonPanel.add(okButton, ButtonPanel.OTHER_BUTTON);
        JButton cancelButton = new JButton("Cancel");
        _buttonPanel.add(cancelButton, ButtonPanel.OTHER_BUTTON);
        return _buttonPanel;
    //code is used to display a tree
    public CheckBoxTree displayTree() {
        DefaultTreeModel treeModel;
        DefaultMutableTreeNode root = new DefaultMutableTreeNode("VRM90");
        for (int i = 0; i < 3; i++) {
            DefaultMutableTreeNode child1 = new DefaultMutableTreeNode("Child" + i);
            for (int j = 0; j < 5; j++) {
                DefaultMutableTreeNode treeNode = new DefaultMutableTreeNode("subChild" + i + "" + j);
                child1.add(treeNode);
            root.add(child1);
        treeModel = new DefaultTreeModel(root);
        _tree = new CheckBoxTree(treeModel);
        return _tree;
May 25, 2009
TODO// TODO Auto-generated method stub
//static int count=0;
            UIManager.setLookAndFeel("com.sun.java.swing.plaf.windows.WindowsClassicLookAndFeel");
        catch (Exception e) {
            e.printStackTrace();
        FilterableCheckBoxTreeSelection fi = FilterableCheckBoxTreeSelection.getInstance();
        fi.setTitle("VRM Filter Panel");
        fi.setResizable(false);
        fi.add(fi.getDemoPanel());
        fi.setSize(new Dimension(400, 400));
        fi.setVisible(true);
    public LinkedHashSet<Object> getSelectedPaths() {
        return selectedPaths;
    public void setSelectedPaths(LinkedHashSet<Object> selectedPaths) {
        this.selectedPaths = selectedPaths;
