by halwhen » Thu Apr 29, 2010 10:01 am
Hi, I'm using CheckBoxTree in my project and have a question. Is there a simple way to select all of the nodes in the tree? there is the clearSelection() from the CheckBoxTreeSelectionModel but how would I select all?
Do I have to iterate through the tree and select each node?
halwhen
by JIDE Support » Thu Apr 29, 2010 10:06 am
Please try to set the digIn flag to true then invoke addSelectionPath(theRoot).
by halwhen » Sat May 01, 2010 7:32 am
That works. Thank you for the quick response.
halwhen
