StyledTableCellRenderer Missing?
Postby markwoon » Mon Mar 22, 2010 9:01 pm
The developer guide for the common layer mentions a StyledTableCellRenderer, but I don't see it in the jar (2.8.x). I don't even see the package it's supposed to be in(com.jidesoft.grid). Is the documentation incorrect, or is this a bug with the jar file?
-Mark
markwoon
Re: StyledTableCellRenderer Missing?
Postby JIDE Support » Tue Mar 23, 2010 8:57 am
I tried to verify the 2.8.5 jar in the website http://www.jidesoft.com/downloads/ and the class is in jide_grids.jar. Would you please double check your class path?
Postby markwoon » Tue Mar 23, 2010 3:21 pm
JIDE Support wrote:I tried to verify the 2.8.5 jar in the website http://www.jidesoft.com/downloads/ and the class is in jide_grids.jar. Would you please double check your class path?
As I mentioned in my post, I am using the common layer. Does this mean that StyledTableCellRenderer is not available to users of the open source common layer only? If so, references to this should be removed from the common layer/oss developer guide.
markwoon
Postby JIDE Support » Tue Mar 23, 2010 5:06 pm
Thanks for your comments. Will adjust the document in 2.9.0.
Postby JIDE Support » Wed Apr 21, 2010 10:47 am
Just so you know, the document is updated in 2.9.0 just released.
