by staiger » Thu Mar 04, 2010 5:34 am
I want to format a number in a pivot table, so that there is no decimal point and no thousand marker.
I tried
ConverterContext ssnConverterContext;
javax.swing.text.MaskFormatter mask = null;
mask = new javax.swing.text.MaskFormatter("#####");
mask.setValueContainsLiteralCharacters(false);
catch (ParseException e) {
ssnConverterContext = new ConverterContext("abr_quart", mask);
pivotDataModel.getField("abr_quart").setConverterContext(ssnConverterContext);
but this didn't work.
Thank you
staiger
by JIDE Support » Thu Mar 04, 2010 11:32 am
Did you register the ConverterContext for Integer.class or String.class?
by staiger » Fri Mar 05, 2010 12:22 am
I dont know, how to do this.
staiger
by JIDE Support » Fri Mar 05, 2010 12:07 pm
Please check out the attached test case modified from JIDE PivotTableDemo FYI.
- Code: Select all
* @(#)PivotTableDemo.java 10/1/2008
* Copyright 2002 - 2008 JIDE Software Inc. All rights reserved.
import com.jidesoft.converter.*;
import com.jidesoft.grid.*;
import com.jidesoft.grouper.AbstractObjectGrouper;
import com.jidesoft.grouper.date.*;
import com.jidesoft.hssf.CsvPivotTableUtils;
import com.jidesoft.hssf.HssfPivotTableUtils;
import com.jidesoft.hssf.HssfTableUtils;
import com.jidesoft.pivot.*;
import org.xml.sax.SAXException;
import javax.swing.table.TableModel;
import javax.xml.parsers.ParserConfigurationException;
import java.io.*;
import java.math.BigDecimal;
import java.text.DecimalFormat;
import java.text.ParseException;
import java.text.SimpleDateFormat;
import java.util.*;
import java.util.zip.GZIPInputStream;
* Demoed Component: {@link com.jidesoft.pivot.PivotTablePane} <br> Required jar files: jide-common.jar, jide-grids.jar
* <br> Required L&F: any L&F
public class PivotTableDemo extends AbstractDemo {
protected PivotTablePane _pivotTablePane;
protected String _lastDirectory = ".";
private Map<String, Boolean> _rowExpansionState;
private Map<String, Boolean> _columnExpansionState;
private static final long serialVersionUID = -5087720822571689883L;
public PivotTableDemo() {
public String getName() {
return "Pivot Grid Demo";
public String getProduct() {
return PRODUCT_NAME_PIVOT;
return "\n" +
"Demoed classes:\n" +
"com.jidesoft.pivot.PivotTablePane";
public int getAttributes() {
return ATTRIBUTE_UPDATED;
static CellStyle HIGH_STYLE = new CellStyle();
static CellStyle LOW_STYLE = new CellStyle();
static CellStyle SUMMARY_STYLE = new CellStyle();
static CellStyle DEFAULT_STYLE = new CellStyle();
static CellStyle HEADER_STYLE = new CellStyle();
static {
HIGH_STYLE.setForeground(Color.WHITE);
HIGH_STYLE.setBackground(Color.RED);
LOW_STYLE.setBackground(Color.YELLOW);
SUMMARY_STYLE.setBackground(new Color(255, 255, 192));
HEADER_STYLE.setFontStyle(Font.BOLD);
JButton saveButton = new JButton(new AbstractAction("Save Layout as XML") {
private static final long serialVersionUID = -5107715775596570738L;
JFileChooser chooser = new JFileChooser() {
protected JDialog createDialog(Component parent) throws HeadlessException {
JDialog dialog = super.createDialog(parent);
dialog.setTitle("Save the layout as an \".xml\" file");
return dialog;
chooser.setCurrentDirectory(new File(_lastDirectory));
int result = chooser.showDialog(((JButton) e.getSource()).getTopLevelAncestor(), "Save");
if (result == JFileChooser.APPROVE_OPTION) {
_lastDirectory = chooser.getCurrentDirectory().getAbsolutePath();
PivotTablePersistenceUtils.save(_pivotTablePane, chooser.getSelectedFile().getAbsolutePath());
catch (ParserConfigurationException e1) {
//noinspection CallToPrintStackTrace
e1.printStackTrace();
catch (IOException e1) {
JButton loadButton = new JButton(new AbstractAction("Load Layout from XML") {
private static final long serialVersionUID = 3732486289243549658L;
dialog.setTitle("Load an \".xml\" file");
return dialog;
int result = chooser.showDialog(((JButton) e.getSource()).getTopLevelAncestor(), "Open");
PivotTablePersistenceUtils.load(_pivotTablePane, chooser.getSelectedFile().getAbsolutePath());
_pivotTablePane.fieldsUpdated();
catch (SAXException e1) {
final JButton exportButton = new JButton(new AbstractAction("Export to Excel 2003 Format") {
private static final long serialVersionUID = 3094181974476823551L;
_pivotTablePane.putClientProperty(HssfTableUtils.CLIENT_PROPERTY_EXCEL_OUTPUT_FORMAT, HssfTableUtils.EXCEL_OUTPUT_FORMAT_2003);
if (!HssfTableUtils.isHssfInstalled()) {
JOptionPane.showMessageDialog((Component) e.getSource(), "Export to Excel feature is disabled because POI-HSSF jar is missing in the classpath.");
return;
outputToExcel(e);
final JButton export2007Button = new JButton(new AbstractAction("Export to Excel 2007 Format") {
private static final long serialVersionUID = -6770274222025672395L;
_pivotTablePane.putClientProperty(HssfTableUtils.CLIENT_PROPERTY_EXCEL_OUTPUT_FORMAT, HssfTableUtils.EXCEL_OUTPUT_FORMAT_2007);
if (!HssfTableUtils.isXssfInstalled()) {
JOptionPane.showMessageDialog((Component) e.getSource(), "Export to Excel 2007 feature is disabled because one or several POI-XSSF dependency jars are missing in the classpath. Please include all the jars from poi release in the classpath and try to run again.");
return;
outputToExcel(e);
final JButton exportToCsvButton = new JButton(new AbstractAction("Export to CSV Format") {
outputToCsv(e);
JButton autoResizeButton = new JButton(new AbstractAction("Auto Resize All Columns") {
_pivotTablePane.autoResizeAllColumns();
JButton verifyButton = new JButton(new AbstractAction("Verify") {
private static final long serialVersionUID = 8735193034044602626L;
IPivotDataModel pivotDataProvider = _pivotTablePane.getPivotDataModel();
if (pivotDataProvider instanceof PivotDataModel) pivotDataProvider.verify();
final JButton getRowButton = new JButton(new AbstractAction("Get Row Expansion State") {
_rowExpansionState = _pivotTablePane.getPivotDataModel().getRowHeaderTableModel().getExpansionState();
final JButton setRowButton = new JButton(new AbstractAction("Set Row Expansion State") {
_pivotTablePane.getPivotDataModel().getRowHeaderTableModel().setExpansionState(_rowExpansionState);
final JButton getColumnButton = new JButton(new AbstractAction("Get Column Expansion State") {
_columnExpansionState = _pivotTablePane.getPivotDataModel().getColumnHeaderTableModel().getExpansionState();
final JButton setColumnButton = new JButton(new AbstractAction("Set Column Expansion State") {
_pivotTablePane.getPivotDataModel().getColumnHeaderTableModel().setExpansionState(_columnExpansionState);
JCheckBox styleCheckBox = new JCheckBox("Show Cell Style");
styleCheckBox.addItemListener(new ItemListener() {
if (e.getStateChange() == ItemEvent.SELECTED) {
_pivotTablePane.getPivotDataModel().setCellStyleProvider(new PivotCellStyleProvider() {
public CellStyle getDataTableCellStyleAt(DataTableModel model, HeaderTableModel rowHeaderModel, HeaderTableModel columnHeaderModel, int rowIndex, int columnIndex) {
if (rowHeaderModel.isSubtotalRowOrColumn(rowIndex) || columnHeaderModel.isSubtotalRowOrColumn(columnIndex)
|| rowHeaderModel.isGrandTotalRowOrColumn(rowIndex) || columnHeaderModel.isGrandTotalRowOrColumn(columnIndex)) {
return SUMMARY_STYLE;
else {
Object value = model.getValueAt(rowIndex, columnIndex);
int summaryType = model.getSummaryTypeAt(rowIndex, columnIndex);
if (summaryType != PivotConstants.SUMMARY_COUNT) {
if (value instanceof Double && (Double) value > 10000) {
return HIGH_STYLE;
else if (value instanceof Double && (Double) value < 50) {
return LOW_STYLE;
return DEFAULT_STYLE;
public CellStyle getColumnHeaderCellStyleAt(HeaderTableModel model, int rowIndex, int columnIndex) {
return HEADER_STYLE;
public CellStyle getRowHeaderCellStyleAt(HeaderTableModel model, int rowIndex, int columnIndex) {
else {
_pivotTablePane.getPivotDataModel().setCellStyleProvider(null);
styleCheckBox.setSelected(_pivotTablePane.getPivotDataModel().getCellStyleProvider() != null);
JCheckBox fieldChooserCheckBox = new JCheckBox("Show Field Chooser");
fieldChooserCheckBox.addItemListener(new ItemListener() {
_pivotTablePane.setFieldChooserVisible(e.getStateChange() == ItemEvent.SELECTED);
fieldChooserCheckBox.setSelected(_pivotTablePane.isFieldChooserVisible());
JCheckBox filterChooserCheckBox = new JCheckBox("Filter Field Chooser");
filterChooserCheckBox.addItemListener(new ItemListener() {
_pivotTablePane.setFieldChooserFilterFieldVisible(e.getStateChange() == ItemEvent.SELECTED);
filterChooserCheckBox.setSelected(_pivotTablePane.isFieldChooserFilterFieldVisible());
JCheckBox grandTotalCheckBox = new JCheckBox("Show Grand Total");
grandTotalCheckBox.addItemListener(new ItemListener() {
_pivotTablePane.getPivotDataModel().setShowGrandTotalForColumn(e.getStateChange() == ItemEvent.SELECTED);
_pivotTablePane.getPivotDataModel().setShowGrandTotalForRow(e.getStateChange() == ItemEvent.SELECTED);
_pivotTablePane.bothHeadersUpdated();
grandTotalCheckBox.setSelected(_pivotTablePane.getPivotDataModel().isShowGrandTotalForColumn() && _pivotTablePane.getPivotDataModel().isShowGrandTotalForRow());
JCheckBox hideFieldOnDragging = new JCheckBox("Hide FieldBox if Dragging Out");
hideFieldOnDragging.addItemListener(new ItemListener() {
_pivotTablePane.setHideFieldOnDraggingOut(e.getStateChange() == ItemEvent.SELECTED);
hideFieldOnDragging.setSelected(_pivotTablePane.isHideFieldOnDraggingOut());
JCheckBox rearrangable = new JCheckBox("Fields Rearrangable");
rearrangable.addItemListener(new ItemListener() {
_pivotTablePane.setRearrangable(e.getStateChange() == ItemEvent.SELECTED);
rearrangable.setSelected(_pivotTablePane.isRearrangable());
JCheckBox shrinkDataFields = new JCheckBox("Shrink Data Fields");
shrinkDataFields.addItemListener(new ItemListener() {
_pivotTablePane.setShrinkDataFieldArea(e.getStateChange() == ItemEvent.SELECTED);
shrinkDataFields.setSelected(_pivotTablePane.isShrinkDataFieldArea());
JCheckBox plainHeaderTables = new JCheckBox("Plain Table Headers");
plainHeaderTables.addItemListener(new ItemListener() {
_pivotTablePane.setPlainHeaderTables(e.getStateChange() == ItemEvent.SELECTED);
plainHeaderTables.setSelected(_pivotTablePane.isPlainHeaderTables());
JCheckBox headerSelectionModel = new JCheckBox("Allow Header Selection");
headerSelectionModel.addItemListener(new ItemListener() {
_pivotTablePane.setHeaderSelectionMode(e.getStateChange() == ItemEvent.SELECTED ? PivotConstants.HEADER_SELECTION_HEADER_TABLE_ONLY : PivotConstants.HEADER_SELECTION_DATA_TABLE_ONLY);
headerSelectionModel.setSelected(_pivotTablePane.getHeaderSelectionMode() == PivotConstants.HEADER_SELECTION_HEADER_TABLE_ONLY);
JCheckBox filterFieldAreaVisible = new JCheckBox("Filter Area Visible");
filterFieldAreaVisible.addItemListener(new ItemListener() {
_pivotTablePane.setFilterFieldAreaVisible(e.getStateChange() == ItemEvent.SELECTED);
filterFieldAreaVisible.setSelected(_pivotTablePane.isFilterFieldAreaVisible());
JCheckBox dataFieldAreaVisible = new JCheckBox("Data Area Visible");
dataFieldAreaVisible.addItemListener(new ItemListener() {
_pivotTablePane.setDataFieldAreaVisible(e.getStateChange() == ItemEvent.SELECTED);
dataFieldAreaVisible.setSelected(_pivotTablePane.isDataFieldAreaVisible());
JCheckBox rowFieldAreaVisible = new JCheckBox("Row Area Visible");
rowFieldAreaVisible.addItemListener(new ItemListener() {
_pivotTablePane.setRowFieldAreaVisible(e.getStateChange() == ItemEvent.SELECTED);
rowFieldAreaVisible.setSelected(_pivotTablePane.isRowFieldAreaVisible());
JCheckBox columnFieldAreaVisible = new JCheckBox("Column Area Visible");
columnFieldAreaVisible.addItemListener(new ItemListener() {
_pivotTablePane.setColumnFieldAreaVisible(e.getStateChange() == ItemEvent.SELECTED);
columnFieldAreaVisible.setSelected(_pivotTablePane.isColumnFieldAreaVisible());
JCheckBox rowFieldFilterable = new JCheckBox("Row Field Filterable");
rowFieldFilterable.addItemListener(new ItemListener() {
_pivotTablePane.setRowFieldFilterable(e.getStateChange() == ItemEvent.SELECTED);
rowFieldFilterable.setSelected(_pivotTablePane.isRowFieldFilterable());
JCheckBox columnFieldFilterable = new JCheckBox("Column Field Filterable");
columnFieldFilterable.addItemListener(new ItemListener() {
_pivotTablePane.setColumnFieldFilterable(e.getStateChange() == ItemEvent.SELECTED);
columnFieldFilterable.setSelected(_pivotTablePane.isColumnFieldFilterable());
JCheckBox dataFieldFilterable = new JCheckBox("Data Field Filterable");
dataFieldFilterable.addItemListener(new ItemListener() {
_pivotTablePane.setDataFieldFilterable(e.getStateChange() == ItemEvent.SELECTED);
dataFieldFilterable.setSelected(_pivotTablePane.isDataFieldFilterable());
JCheckBox showFilterIcon = new JCheckBox("Show Filter Icon");
showFilterIcon.addItemListener(new ItemListener() {
_pivotTablePane.setShowFilterIcon(e.getStateChange() == ItemEvent.SELECTED);
showFilterIcon.setSelected(_pivotTablePane.isShowFilterIcon());
JCheckBox columnAutoResizable = new JCheckBox("Column Auto Resizable");
columnAutoResizable.addItemListener(new ItemListener() {
_pivotTablePane.setColumnAutoResizable(e.getStateChange() == ItemEvent.SELECTED);
columnAutoResizable.setSelected(_pivotTablePane.isColumnAutoResizable());
JCheckBox columnWidthRespectField = new JCheckBox("Column Width From Field");
columnWidthRespectField.addItemListener(new ItemListener() {
_pivotTablePane.setRespectFieldPreferredWidth(e.getStateChange() == ItemEvent.SELECTED);
_pivotTablePane.getPivotDataModel().getField("ProductSales").setPreferredWidth(30);
_pivotTablePane.getPivotDataModel().getColumnHeaderTableModel().fireTableStructureChanged();
columnWidthRespectField.setSelected(_pivotTablePane.isRespectFieldPreferredWidth());
JCheckBox considerRowFieldLength = new JCheckBox("Auto Resize Counting Row Field");
considerRowFieldLength.addItemListener(new ItemListener() {
_pivotTablePane.setConsiderRowFieldWidth(e.getStateChange() == ItemEvent.SELECTED);
considerRowFieldLength.setSelected(_pivotTablePane.isConsiderRowFieldWidth());
JCheckBox hideSummaryValues = new JCheckBox("Hide Summary Values");
hideSummaryValues.addItemListener(new ItemListener() {
_pivotTablePane.getPivotDataModel().setHideSummaryValues(e.getStateChange() == ItemEvent.SELECTED);
hideSummaryValues.setSelected(_pivotTablePane.getPivotDataModel().isHideSummaryValues());
JPanel panel = new JPanel(new GridLayout(0, 2, 5, 5));
panel.add(saveButton);
panel.add(loadButton);
panel.add(exportButton);
panel.add(export2007Button);
panel.add(exportToCsvButton);
panel.add(autoResizeButton);
panel.add(verifyButton);
panel.add(getRowButton);
panel.add(setRowButton);
panel.add(getColumnButton);
panel.add(setColumnButton);
JButton button = new JButton();
button.setVisible(false);
panel.add(button);
panel.add(styleCheckBox);
panel.add(fieldChooserCheckBox);
panel.add(filterChooserCheckBox);
panel.add(grandTotalCheckBox);
panel.add(rearrangable);
panel.add(shrinkDataFields);
panel.add(plainHeaderTables);
panel.add(headerSelectionModel);
panel.add(filterFieldAreaVisible);
panel.add(dataFieldAreaVisible);
panel.add(rowFieldAreaVisible);
panel.add(columnFieldAreaVisible);
panel.add(rowFieldFilterable);
panel.add(columnFieldFilterable);
panel.add(dataFieldFilterable);
panel.add(hideFieldOnDragging);
panel.add(showFilterIcon);
panel.add(columnAutoResizable);
panel.add(considerRowFieldLength);
panel.add(columnWidthRespectField);
panel.add(hideSummaryValues);
// panel.add(new JButton(new AbstractAction("Repaint") {
// public void actionPerformed(ActionEvent e) {
// long start = System.currentTimeMillis();
// for (int i = 0; i < 10; i++) {
// _pivotTablePane.paintImmediately(0, 0, _pivotTablePane.getWidth(), _pivotTablePane.getHeight());
// long end = System.currentTimeMillis();
// System.out.println(end - start);
// panel.add(new JButton(new AbstractAction("Update") {
// Thread runnable = new Thread() {
// public void run() {
// try {
// Thread.sleep(5000);
// catch (InterruptedException e1) {
// e1.printStackTrace();
// Runnable runnable = new Runnable() {
// System.out.println("updated");
// _pivotTablePane.bothHeadersUpdated();
// SwingUtilities.invokeLater(runnable);
// runnable.start();
return panel;
final TableModel tableModel = createProductReportsTableModel();
// final TableModel tableModel = createCustomerReportsTableModel();
if (tableModel == null) {
return new JLabel("Failed to read data file");
final CalculatedTableModel calculatedTableModel = setupProductDetailsCalculatedTableModel(tableModel);
// final CalculatedTableModel calculatedTableModel = setupCustomerReportsCalculatedTableModel(tableModel);
final PivotDataModel pivotDataModel = setupProductDetailsPivotDataModel(calculatedTableModel);
// final PivotDataModel pivotDataModel = setupCustomerReportsPivotDataModel(calculatedTableModel);
_pivotTablePane = new PivotTablePane(pivotDataModel);
// _pivotTablePane.getDataTable().addMouseListener(new MouseAdapter() {
// public void mouseClicked(MouseEvent e) {
// int row = ((JTable) e.getSource()).rowAtPoint(e.getPoint());
// int column = ((JTable) e.getSource()).columnAtPoint(e.getPoint());
// java.util.List<Integer> list = _pivotTablePane.getPivotDataModel().getDataAt(row, column);
// if (list != null) {
// for (Integer rowIndex : list) {
// System.out.println(pivotDataModel.getTableModel().getValueAt(rowIndex, pivotDataModel.getField("ProductSales").getModelIndex()));
_pivotTablePane.setColumnAutoResizable(true);
return _pivotTablePane;
private TableModel createProductReportsTableModel() {
InputStream resource = this.getClass().getClassLoader().getResourceAsStream("ProductReports.txt.gz");
if (resource == null) {
return null;
InputStream in = new GZIPInputStream(resource);
BufferedReader reader = new BufferedReader(new InputStreamReader(in, "UTF-8"));
Vector<Vector<Object>> data = new Vector<Vector<Object>>();
Vector<String> columnNames = new Vector<String>();
String columnsLine = reader.readLine(); // skip first line
String[] columnValues = columnsLine.split("\t");
columnNames.addAll(Arrays.asList(columnValues));
do {
String line = reader.readLine();
if (line == null || line.length() == 0) {
break;
String[] values = line.split("\t");
Vector<Object> lineData = new Vector<Object>();
lineData.add(values[0]); // category name
lineData.add(values[1]); // product name
String value = values[2];
if (value.startsWith("$")) {
float f = Float.parseFloat(value.substring(1));
lineData.add(f); // product amount
String value = values[3];
SimpleDateFormat format = new SimpleDateFormat("MM/dd/yyyy hh:mm:ss");
Date date = format.parse(value);
lineData.add(date); // order date
e.printStackTrace();
for (int i = 0; i < 1; i++) {
data.add(lineData);
while (true);
// System.out.println(data.size());
return new DefaultContextSensitiveTableModel(data, columnNames) {
private static final long serialVersionUID = -4217547219462901851L;
public Class<?> getColumnClass(int columnIndex) {
switch (columnIndex) {
case 0:
case 1:
return String.class;
case 2:
return Float.class;
case 3:
return Date.class;
return super.getColumnClass(columnIndex);
public ConverterContext getConverterContextAt(int row, int column) {
return column == 2 ? CurrencyConverter.CONTEXT : null;
catch (IOException e) {
return null;
private CalculatedTableModel setupProductDetailsCalculatedTableModel(TableModel tableModel) {
CalculatedTableModel calculatedTableModel = new CalculatedTableModel(tableModel);
calculatedTableModel.addAllColumns();
SingleColumn column = new SingleColumn(tableModel, "ProductName");
column.setObjectGrouper(new AbstractObjectGrouper() {
public Class<?> getType() {
public Object getValue(Object value) {
if (value != null) {
String name = value.toString();
return name.substring(0, 1);
else {
return null;
return "Alphabetical";
calculatedTableModel.addColumn(column);
calculatedTableModel.addColumn(new SingleColumn(tableModel, "ShippedDate", "Year", new DateYearGrouper()));
calculatedTableModel.addColumn(new SingleColumn(tableModel, "ShippedDate", "Quarter", new DateQuarterGrouper()));
calculatedTableModel.addColumn(new SingleColumn(tableModel, "ShippedDate", "Month", new DateMonthGrouper()));
calculatedTableModel.addColumn(new SingleColumn(tableModel, "ShippedDate", "Week", new DateWeekOfYearGrouper()));
calculatedTableModel.addColumn(new SingleColumn(tableModel, "ShippedDate", "Day of Year", new DateDayOfYearGrouper()));
calculatedTableModel.addColumn(new SingleColumn(tableModel, "ShippedDate", "Day of Month", new DateDayOfMonthGrouper()));
calculatedTableModel.addColumn(new AbstractCalculatedColumn(tableModel, "Sales2", BigDecimal.class) {
private static final long serialVersionUID = -6309145400597924345L;
public Object getValueAt(int rowIndex) {
Object valueAt = getActualModel().getValueAt(rowIndex, 2);
if (valueAt instanceof Float) {
return new BigDecimal((Float) valueAt);
return "--";
public int[] getDependingColumns() {
return new int[]{2};
return calculatedTableModel;
private PivotDataModel setupProductDetailsPivotDataModel(TableModel derivedTableModel) {
// use CachedTableModel will use more memory but the speed will be faster.
// final PivotDataModel pivotDataModel = new PivotDataModel(new CachedTableModel(derivedTableModel));
final PivotDataModel pivotDataModel = new PivotDataModel(derivedTableModel);
// here is an example to add your own summary type.
pivotDataModel.setSummaryCalculator(new DefaultSummaryCalculator() {
final int SUMMARY_LAST_VALUE = PivotConstants.SUMMARY_RESERVED_MAX + 1;
private Object _lastValue;
public void addValue(IPivotDataModel dataModel, PivotField field, int rowIndex, int columnIndex, Object v) {
super.addValue(dataModel, field, rowIndex, columnIndex, v);
if (v instanceof Number) {
_lastValue = ((Number) v).doubleValue();
public void clear() {
super.clear();
_lastValue = 0;
public int getNumberOfSummaries() {
return super.getNumberOfSummaries() + 1;
public String getSummaryName(Locale locale, int type) {
if (type == SUMMARY_LAST_VALUE) {
return "Last Value";
return super.getSummaryName(locale, type);
public Object getSummaryResult(int type) {
return _lastValue;
return super.getSummaryResult(type);
public int[] getAllowedSummaries(Class<?> type, ConverterContext context) {
int[] summaries = super.getAllowedSummaries(type, context);
int[] newSummaries = new int[summaries.length + 1];
System.arraycopy(summaries, 0, newSummaries, 0, summaries.length);
newSummaries[summaries.length] = SUMMARY_LAST_VALUE;
return newSummaries;
pivotDataModel.getField("CategoryName").setAreaType(PivotField.AREA_ROW);
pivotDataModel.getField("CategoryName").setAreaIndex(1);
pivotDataModel.getField("CategoryName").setTitle("Category Name");
pivotDataModel.getField("CategoryName").setSubtotalType(PivotField.SUBTOTAL_AUTOMATIC);
// sample code to add a filter icon to the field box if there are filters.
// pivotDataModel.getField("CategoryName").addPropertyChangeListener(PivotField.PROPERTY_SELECTED_POSSIBLE_VALUES, new PropertyChangeListener() {
// public void propertyChange(PropertyChangeEvent evt) {
// Object[] newValue = (Object[]) evt.getNewValue();
// PivotField field = (PivotField) evt.getSource();
// if (newValue == null) {
// field.setIcon(null);
// else {
// field.setIcon(GridIconsFactory.getImageIcon(GridIconsFactory.Table.FILTER));
pivotDataModel.getField("ProductName").setAreaType(PivotField.AREA_ROW);
pivotDataModel.getField("ProductName").setAreaIndex(2);
pivotDataModel.getField("ProductName").setTitle("Product Name");
pivotDataModel.getField("ProductName").setNullValueAllowed(true);
pivotDataModel.getField("ProductName (Alphabetical)").setTitle("Product Name (Alphabetical)");
pivotDataModel.getField("ProductSales").setAreaType(PivotField.AREA_DATA);
pivotDataModel.getField("ProductSales").setAreaIndex(1);
pivotDataModel.getField("ProductSales").setTitle("Sales");
pivotDataModel.getField("ProductSales").setSummaryType(PivotField.SUMMARY_SUM);
pivotDataModel.getField("Sales2").setTitle("Sales2");
pivotDataModel.getField("Sales2").setSummaryType(PivotField.SUMMARY_SUM);
pivotDataModel.getField("Sales2").setConverterContext(CurrencyConverter.CONTEXT);
pivotDataModel.getField("Year").setAreaType(PivotField.AREA_COLUMN);
pivotDataModel.getField("Year").setAreaIndex(1);
pivotDataModel.getField("Year").setSummaryType(PivotField.SUMMARY_NONE);
pivotDataModel.getField("Year").setGrandTotalSummaryType(PivotField.SUMMARY_NONE);
pivotDataModel.getField("Year").setSubtotalType(PivotField.SUBTOTAL_CUSTOM);
pivotDataModel.getField("Year").setCustomSubtotals(new int[]{PivotField.SUMMARY_STDDEV, PivotField.SUMMARY_SUM});
pivotDataModel.getField("Quarter").setAreaType(PivotField.AREA_COLUMN);
pivotDataModel.getField("Quarter").setSubtotalType(PivotField.SUBTOTAL_CUSTOM);
pivotDataModel.getField("Quarter").setCustomSubtotals(new int[]{PivotField.SUMMARY_STDDEV, PivotField.SUMMARY_SUM, PivotField.SUMMARY_MAX});
pivotDataModel.getField("Quarter").setAreaIndex(2);
pivotDataModel.getField("Quarter").setSummaryType(PivotField.SUMMARY_NONE);
pivotDataModel.getField("Quarter").setGrandTotalSummaryType(PivotField.SUMMARY_NONE);
pivotDataModel.getField("Month").setAreaType(PivotField.AREA_COLUMN);
pivotDataModel.getField("Month").setAreaIndex(3);
pivotDataModel.getField("Month").setSummaryType(PivotField.SUMMARY_NONE);
pivotDataModel.getField("Month").setGrandTotalSummaryType(PivotField.SUMMARY_NONE);
pivotDataModel.getField("Week").setSummaryType(PivotField.SUMMARY_NONE);
pivotDataModel.getField("Week").setGrandTotalSummaryType(PivotField.SUMMARY_NONE);
pivotDataModel.getField("ShippedDate").setSummaryType(PivotField.SUMMARY_NONE);
pivotDataModel.getField("ShippedDate").setGrandTotalSummaryType(PivotField.SUMMARY_NONE);
pivotDataModel.setShowGrandTotalForColumn(true);
pivotDataModel.setShowGrandTotalForRow(true);
// the comments below are for performance testing.
// System.gc();
// System.gc();
// System.gc();
// long startMem = Runtime.getRuntime().totalMemory() - Runtime.getRuntime().freeMemory();
pivotDataModel.calculate();
// System.out.println(System.currentTimeMillis() - start);
// System.gc();
// System.gc();
// System.gc();
// System.out.println((Runtime.getRuntime().totalMemory() - Runtime.getRuntime().freeMemory()) - startMem);
// find out how long it takes to read the table model as comparision
// PivotField[] rows = pivotDataModel.getRowFields();
// PivotField[] columns = pivotDataModel.getColumnFields();
// int[] indices = new int[rows.length + columns.length];
// for (int i = 0; i < rows.length; i++) {
// PivotField field = rows[i];
// indices[i] = field.getModelIndex();
// for (int i = 0; i < columns.length; i++) {
// PivotField field = columns[i];
// indices[i + rows.length] = field.getModelIndex();
// start = System.currentTimeMillis();
// PivotDataSource model = pivotDataModel.getDataSource();
// int rowCount = model.getRowCount();
// for (int row = 0; row < rowCount; row++) {
// for (int index : indices) {
// model.getValueAt(row, index);
return pivotDataModel;
@SuppressWarnings({"UnusedDeclaration"})
private TableModel createCustomerReportsTableModel() {
InputStream resource = this.getClass().getClassLoader().getResourceAsStream("CustomerReports.txt.gz");
return null;
do {
break;
if (values.length < 1)
lineData.add(null); // product name
else {
lineData.add(values[0]); // product name
if (values.length < 2)
lineData.add(null); // company name
else
lineData.add(values[1]); // company name
if (values.length < 3)
lineData.add(null); // order date
else {
if (values.length < 4)
lineData.add(null); // product amount
else {
data.add(lineData);
while (true);
private static final long serialVersionUID = 8718992031537900737L;
case 0:
case 1:
case 2:
return Date.class;
case 3:
return Float.class;
return column == 3 ? CurrencyConverter.CONTEXT : null;
public boolean isCellEditable(int row, int column) {
return true;
return null;
private CalculatedTableModel setupCustomerReportsCalculatedTableModel(TableModel tableModel) {
calculatedTableModel.addColumn(new SingleColumn(tableModel, "OrderDate", "Year", new DateYearGrouper()));
calculatedTableModel.addColumn(new SingleColumn(tableModel, "OrderDate", "Quarter", new DateQuarterGrouper()));
calculatedTableModel.addColumn(new SingleColumn(tableModel, "OrderDate", "Month", new DateMonthGrouper()));
calculatedTableModel.addColumn(new SingleColumn(tableModel, "OrderDate", "Week", new DateWeekOfYearGrouper()));
calculatedTableModel.addColumn(new SingleColumn(tableModel, "OrderDate", "Day of Year", new DateDayOfYearGrouper()));
calculatedTableModel.addColumn(new SingleColumn(tableModel, "OrderDate", "Day of Month", new DateDayOfMonthGrouper()));
private IPivotDataModel setupCustomerReportsPivotDataModel(CalculatedTableModel calculatedTableModel) {
final IPivotDataModel pivotDataModel = new PivotDataModel(calculatedTableModel);
pivotDataModel.getField("ProductName").setAreaIndex(0);
pivotDataModel.getField("ProductName").setSubtotalType(PivotField.SUBTOTAL_AUTOMATIC);
pivotDataModel.getField("CompanyName").setAreaType(PivotField.AREA_ROW);
pivotDataModel.getField("CompanyName").setAreaIndex(1);
pivotDataModel.getField("CompanyName").setTitle("Company Name");
pivotDataModel.getField("CompanyName").setSubtotalType(PivotField.SUBTOTAL_AUTOMATIC);
pivotDataModel.getField("ProductAmount").setAreaType(PivotField.AREA_DATA);
pivotDataModel.getField("ProductAmount").setSummaryType(PivotField.SUMMARY_SUM);
pivotDataModel.getField("ProductAmount").setTitle("Amount");
pivotDataModel.getField("Year").setConverterContext(YearNameConverter.CONTEXT);
pivotDataModel.getField("Year").setEditorContext(ContextSensitiveCellRenderer.CONTEXT_SENSITIVE_CONTEXT);
pivotDataModel.getField("Quarter").setConverterContext(QuarterNameConverter.CONTEXT);
pivotDataModel.getField("Quarter").setEditorContext(ContextSensitiveCellRenderer.CONTEXT_SENSITIVE_CONTEXT);
pivotDataModel.getField("Quarter").setCustomSubtotals(new int[]{PivotField.SUMMARY_STDDEV, PivotField.SUMMARY_SUM, PivotField.SUMMARY_MEAN});
pivotDataModel.getField("Month").setConverterContext(MonthNameConverter.CONTEXT);
pivotDataModel.getField("Month").setEditorContext(ContextSensitiveCellRenderer.CONTEXT_SENSITIVE_CONTEXT);
return "P1.PivotTablePane";
PivotDataModel.setValueImmutable(true);
DecimalFormat format = new DecimalFormat();
format.setMinimumFractionDigits(0);
format.setMaximumFractionDigits(0);
format.setGroupingUsed(false);
DoubleConverter converter = new DoubleConverter(format);
ObjectConverterManager.registerConverter(Float.class, converter, CurrencyConverter.CONTEXT);
showAsFrame(new PivotTableDemo());
private void outputToCsv(ActionEvent e) {
dialog.setTitle("Export the content to a CSV file");
return dialog;
int result = chooser.showDialog(((JButton) e.getSource()).getTopLevelAncestor(), "Export");
System.out.println("Exporting to " + chooser.getSelectedFile().getAbsolutePath());
CsvPivotTableUtils.export(_pivotTablePane, chooser.getSelectedFile().getAbsolutePath(), new HssfTableUtils.DefaultCellValueConverter() {
public int getDataFormat(JTable table, Object value, int rowIndex, int columnIndex) {
if (value instanceof Double) {
return 2; // use 0.00 format
// in case you want custom format, you can use this code below to do it.
// return ((HSSFWorkbook) table.getClientProperty("HssfTableUtils.HSSFWorkbook")).createDataFormat().getFormat("#,##0.000000");
else if (value instanceof Date) {
return 0xe; // use m/d/yy
return super.getDataFormat(table, value, rowIndex, columnIndex);
System.out.println("Exported");
catch (IOException ex) {
ex.printStackTrace();
private void outputToExcel(ActionEvent e) {
dialog.setTitle("Export the content to an Excel file");
return dialog;
HssfPivotTableUtils.export(_pivotTablePane, chooser.getSelectedFile().getAbsolutePath(), "Pivot", false, new HssfTableUtils.DefaultCellValueConverter() {
public void dispose() {
_pivotTablePane = null;
