Suggestions for component to be used
Postby RajaRajeswari_V » Thu Feb 25, 2010 11:58 pm
I am trying to make a select ProjectType template kind of dialog. For ex in Visual studio when you click on New Project a Select ProjectTemplate dialog opens up.I need something similar to that.I have seen the options Dialog in Jide, but i need to customize it according to my requirement. Can you suggest me an appropriate Jide Dialog to extend other than this Multi Page Dialog as my requirement would be a single page but i need the pagelist panel to be bigger.
RajaRajeswari_V
Re: Suggestions for component to be used
Postby JIDE Support » Fri Feb 26, 2010 11:15 am
Basically you could just override StandardDialog to customize your own dialog. Sorry that I cannot quite get your request. Looks like you have only one single page. If this is the case, why you need the page list panel to be bigger?
Postby CatWoman » Tue Oct 26, 2010 11:52 pm
JIDE Support wrote:Basically you could just override StandardDialog to customize your own dialog. Sorry that I cannot quite get your request. Looks like you have only one single page. If this is the case, why you need the page list panel to be bigger?
i agree on this,.
try it it will work for sure.
CatWoman
