by robert » Tue Jan 26, 2010 9:22 am
I'm using CheckBoxTree in my project and have a couple questions/suggestions:
1) Is there a simple way to unselect all of the nodes in the tree? I'm looking for something similar to the clearSelection() method in CheckBoxList. The clearSelection() method in CheckBoxTree does not seem to do anything. Or do I need to iterate through the tree and unselect each node?
2) In my CheckBoxList I have set setClickInCheckBoxOnly() to false so that the user can click on the text or the checkbox in order to select the item. I do not see a similar method for CheckBoxTree. I would like to have consistent behaviour between the list and tree, but I'm not sure if this is possible.
robert
by JIDE Support » Tue Jan 26, 2010 10:40 am
Thanks for your suggestion. We will consider add a similar flag in CheckBoxTree in 2.8.3.
Please try to invoke CheckBoxTree#getCheckBoxTreeSelectionModel()#clearSelection() to unselect all of the nodes in the tree. Please check out JIDE CheckBoxTreeDemo for your reference.
by robert » Tue Jan 26, 2010 3:45 pm
Thanks for the assistance. I was mistakenly using getSelectionModel() when I should have been using getCheckBoxTreeSelectionModel().
robert
by JIDE Support » Fri Jan 29, 2010 11:55 am
Just so you know, the new APIs similar to CheckBoxList are provided in CheckBoxTree in 2.8.3.
