JCombobox can't change selection with ChecBoxTree
Postby julien1486 » Wed Dec 30, 2009 2:07 am
Hi everyone !
I'm using a CheckBoxTree in a JDialog in order to display somes permissions on the application for a particular user.
This particular user is selected with a JCombobox which should fire an "itemStateChanged" event when the selection changes.
But most of the time, the JCombobox do not fire event at all, the selection do not change. If I comment the lines related to the CheckBoxTree I don't have the problem anymore.
Is there a conflict between CheckBoxTree and JCombobox ? (Or something else ?)
Thanks a lot for your help
julien1486
Re: JCombobox can't change selection with ChecBoxTree
Postby JIDE Support » Wed Dec 30, 2009 7:49 am
So you have a JComboBox and a CheckBoxTree in your dialog. You are expecting that when you choose user in the JComboBox, the selections in CheckBoxTree should be updated accordingly. Am I right? If this is the case, I can't see the possibility of confliction between CheckBoxTree and JComboBox. Would you please share with us a test case?
