CheckBoxTree stack overflow.
Postby Thomas Corbin » Tue Dec 22, 2009 7:19 pm
Basically, to reproduce, you just run the program and click one of the
checkboxes. This is a problem with CheckBoxTree's 'dig in' mode in which
it selects the parent node if all of the child nodes are selected. But,
if you programmatically select the child nodes and not just the parent
node, it causes this stack overflow.
import java.awt.Frame;
import java.util.Enumeration;
import javax.swing.JDialog;
import javax.swing.tree.DefaultMutableTreeNode;
import javax.swing.tree.DefaultTreeModel;
import javax.swing.tree.TreePath;
import com.jidesoft.swing.CheckBoxTree;
import com.jidesoft.swing.CheckBoxTreeSelectionModel;
 * TO REPRODUCE BUG:
 * Run this code, click on a checkbox, wait for stack overflow error in
 * AWT event queue.
 * Exception in thread "AWT-EventQueue-0" java.lang.StackOverflowError
        at java.util.AbstractCollection.<init>(AbstractCollection.java:49)
        at java.util.AbstractSet.<init>(AbstractSet.java:46)
        at java.util.HashSet.<init>(HashSet.java:85)
        at com.jidesoft.swing.CheckBoxTreeSelectionModel.addSelectionPaths(Unknown Source)
        at com.jidesoft.swing.CheckBoxTreeSelectionModel.isPathSelected(Unknown Source)
@SuppressWarnings( "serial" )
public class CheckBoxTreeBug extends JPanel
    CheckBoxTreeBug()
        DefaultMutableTreeNode root = new DefaultMutableTreeNode( "Contents" );
        root.add( new DefaultMutableTreeNode( "Llama" ) );
        root.add( new DefaultMutableTreeNode( "Aardvark" ) );
        root.add( new DefaultMutableTreeNode( "Platypus" ) );
        root.add( new DefaultMutableTreeNode( "Rutabaga" ) );
        DefaultTreeModel treeModel = new DefaultTreeModel( root );
        CheckBoxTree tree = new CheckBoxTree( treeModel );
        CheckBoxTreeSelectionModel selmodel = tree.getCheckBoxTreeSelectionModel();
        //    Select all child nodes of the root
        Enumeration<?> kids = root.children();
        while( kids.hasMoreElements() )
            DefaultMutableTreeNode kid = (DefaultMutableTreeNode) kids.nextElement();
            selmodel.addSelectionPath( new TreePath( kid.getPath() ) );
        add( tree );
    public static void main( String[] args )
        JDialog    dialog = new JDialog( (Frame) null, "CheckBoxTreeBug" );
        dialog.setDefaultCloseOperation( JDialog.DISPOSE_ON_CLOSE );
        dialog.getContentPane().add( new CheckBoxTreeBug() );
        dialog.pack();
        dialog.setVisible( true );
Thomas Corbin
Re: CheckBoxTree stack overflow.
Postby JIDE Support » Wed Dec 23, 2009 10:33 am
This is an issue introduced while we tried to improve the selection performance. We will fix it in 2.8.3.
For now, please try the following code in your test case for workaround.
        for (int i = 1; i < 5; i++) {
            selmodel.setBatchMode(true);
            selmodel.addSelectionPath( tree.getPathForRow(i) );
            selmodel.setBatchMode(false);
Postby JIDE Support » Fri Jan 29, 2010 12:26 pm
Just so you know, this is fixed in 2.8.3.
Postby fcarballo » Wed Feb 24, 2010 8:25 am
Hi, I'm having the same problem. I downloded the version 2.8.4 and 2.8.3 but it didn't works. Thomas, did you fix it with the new version?
fcarballo
Postby Thomas Corbin » Wed Feb 24, 2010 9:02 am
Sorry, no - I haven't downloaded 2.8.3 yet.
I'll try to do it sometime this week, though I'm busy.
I never enjoy downloading new versions, it always seems like a pain.
Thomas Corbin
Postby JIDE Support » Wed Feb 24, 2010 10:37 am
Looks like it is still broken. Sorry about that. We will figure out a solution for you in 2.8.5 and 2.9.0.
Postby fcarballo » Fri Feb 26, 2010 1:51 pm
Hi, I saw that this issue was fixed on trunk and I download trunk source, and work. But I get a new problem.
I'm trying to generate some checkbox triggers, so, when I click on checkbox 3 I want that checkbox 2 appears checked.
Here is my example code:
import javax.swing.event.TreeSelectionEvent;
import javax.swing.event.TreeSelectionListener;
@SuppressWarnings("serial")
public class CheckBoxTreeSimpleBug extends JPanel {
   private CheckBoxTree tree = null;
   private CheckBoxTree getCheckBoxTree() {
      return tree;
   CheckBoxTreeSimpleBug() {
      DefaultMutableTreeNode root = new DefaultMutableTreeNode("Contents");
      root.add(new DefaultMutableTreeNode("1"));
      root.add(new DefaultMutableTreeNode("2"));
      root.add(new DefaultMutableTreeNode("3"));
      root.add(new DefaultMutableTreeNode("4"));
      DefaultTreeModel treeModel = new DefaultTreeModel(root);
      tree = new CheckBoxTree(treeModel);
      tree.setDigIn(true);
      tree.getCheckBoxTreeSelectionModel().setSingleEventMode(true);
      tree.getCheckBoxTreeSelectionModel().addTreeSelectionListener(new TreeSelectionListener() {
         public void valueChanged(TreeSelectionEvent event) {
            if (getCheckBoxTree().isCheckBoxEnabled()) {
               Integer row = getRow(event);
               if (row != null) {
                  if (row == 3) {
                     CheckBoxTreeSelectionModel selModel = getCheckBoxTree().getCheckBoxTreeSelectionModel();
                     selModel.addSelectionPath(getCheckBoxTree().getPathForRow(2));
      add(getCheckBoxTree());
   private Integer getRow(TreeSelectionEvent event) {
      TreePath[] treePaths = event.getPaths();
      if (treePaths.length == 1) {
         TreePath treePath = treePaths[0];
         DefaultMutableTreeNode lastPathComponent = (DefaultMutableTreeNode) treePath.getLastPathComponent();
         if (lastPathComponent.getChildCount() == 0) {
            return getCheckBoxTree().getRowForPath(new TreePath(lastPathComponent.getPath()));
      return null;
      JDialog dialog = new JDialog((Frame) null, "CheckBoxTreeBug");
      dialog.setDefaultCloseOperation(JDialog.DISPOSE_ON_CLOSE);
      dialog.getContentPane().add(new CheckBoxTreeSimpleBug());
      dialog.pack();
      dialog.setVisible(true);
When I click on "3", checkbox "2" appear clicked, but checkbox "3" no.
I think that the code is ok. I try with and without selModel.setBatchMode(true); selModel.setBatchMode(false); but it doesn't work.
Please can you help me.. When do you think the new version will be released?
fcarballo
Postby JIDE Support » Fri Feb 26, 2010 3:08 pm
Thanks for the bug report. We will fix it in both 2.8.5 and 2.9.0 as well. 2.8.5 will be released next week.
Postby JIDE Support » Wed Mar 03, 2010 8:35 pm
Just so you know, this is fixed in 2.8.5 just released.
Postby JIDE Support » Wed Apr 21, 2010 10:46 am
Just so you know, this is also fixed in 2.9.0 just released.
