Disable node in MultiplePageDialog
Postby huazheng » Tue Dec 01, 2009 9:58 am
Is it possible? AbstractDialogPage#setEnable doesn't seem to have any effect.
DefaultMutableTreeNode doesn't seem to support enable/disable. Maybe you can add a protected createTreeNode(page) in MultiplePageDialog so I can use a subclass that supports it (example). Thanks!
huazheng
Re: Disable node in MultiplePageDialog
Postby JIDE Support » Wed Dec 02, 2009 8:39 am
Thanks for suggestion. We will try to add this feature in 2.8.2.
Postby JIDE Support » Wed Dec 23, 2009 8:06 am
Just so you know, setPageEnabled(false) will disable the tree node in 2.8.2.
