Icon with StyledTreeCellRenderer
Postby stars » Wed Nov 25, 2009 8:07 am
I'm using StyledTreeCellRenderer in JTree. There is a strange behaviour that I reproduce into Jide examples (@see attachment).
The UserObject from node is updated to the customizeStyledLabel add an icon. The icon is printed but the text is truncated with 3 dots.
In StyledLabelDemo.java, expand the 2nd error node, clicks on button then collapses/expands this node: icon is well painted but text is printed with 3 dots. If node is not expanded before UserObject modification, the display is correct.
Any ideas ?
(15.03 KiB) Downloaded 1957 times
stars
Re: Icon with StyledTreeCellRenderer
Postby JIDE Support » Wed Nov 25, 2009 9:13 am
The reason is that BasicTreeUI has a cache to store the bounds of the paths and it does not trigger recalculation while setting object. I modified your test case to customize the BasicTreeUI to make it work FYI.
 * @(#)StyledLabelDemo.java 9/6/2005
 * Copyright 2002 - 2005 JIDE Software Inc. All rights reserved.
import com.jidesoft.grid.JideTable;
import com.jidesoft.grid.StyledTableCellRenderer;
import com.jidesoft.list.StyledListCellRenderer;
import com.jidesoft.swing.JideButton;
import com.jidesoft.swing.PartialLineBorder;
import com.jidesoft.swing.StyleRange;
import com.jidesoft.swing.StyledLabel;
import com.jidesoft.tree.StyledTreeCellRenderer;
import javax.swing.plaf.basic.BasicTreeUI;
import javax.swing.border.TitledBorder;
import javax.swing.table.DefaultTableModel;
import javax.swing.tree.DefaultMutableTreeNode;
import javax.swing.tree.DefaultTreeModel;
import javax.swing.tree.TreeCellRenderer;
 * Demoed Component: {@link com.jidesoft.swing.StyledLabel} <br> Required jar files: jide-common.jar <br> Required L&F:
 * any L&F
public class StyledLabelDemo extends AbstractDemo {
    private DefaultMutableTreeNode test_child;
    private JTree _tree;
    public StyledLabelDemo() {
    public String getName() {
        return "StyledLabel Demo";
    public String getProduct() {
        return PRODUCT_NAME_COMMON;
        return "StyledLabel is an enhanced JLabel to display the text in different colors and font and can decorate with all kinds of line styles.\n" +
                "Demoed classes:\n" +
                "com.jidesoft.swing.StyledLabel";
        JPanel pane = new JPanel(new GridLayout(0, 1, 5, 5));
        pane.add(createLabelsPanel());
        pane.add(createTreePanel());
        pane.add(createTablePanel());
        pane.add(createListPanel());
        pane.add(modifyNode());
        return pane;
    private JideButton modifyNode() {
        JideButton jideButton = new JideButton("MODIFY ICON");
        jideButton.addActionListener(new ActionListener() {
                if (test_child != null) {
                    test_child.setUserObject(ADD_ICON);
                    _tree.revalidate();
                    ((CustomizeTreeUI) _tree.getUI()).updateTreeCashSize();
        return jideButton;
    private static final String SEVERE = "Severe Warnings";
    private static final String REGULAR = "Regular Warnings";
    private static final String MESSAGES = "Messages";
    private static final String ERROR_STRING = "Error";
    private static final String UNDERLINED = "Underlined";
    private static final String STRIKE_THROUGH = "Strikethrough";
    private static final String ADD_ICON = "Icon";
    private JComponent createTreePanel() {
        JPanel panel = new JPanel(new BorderLayout());
        DefaultMutableTreeNode root = new DefaultMutableTreeNode("ROOT");
        DefaultMutableTreeNode severe = new DefaultMutableTreeNode(SEVERE + " (10 warnings)");
        severe.add(new DefaultMutableTreeNode(ERROR_STRING));
        severe.add(new DefaultMutableTreeNode(UNDERLINED));
        severe.add(new DefaultMutableTreeNode(STRIKE_THROUGH));
        root.add(severe);
        DefaultMutableTreeNode regular = new DefaultMutableTreeNode(REGULAR + " (2 warnings)");
        test_child = new DefaultMutableTreeNode(ERROR_STRING);
        regular.add(test_child);
        regular.add(new DefaultMutableTreeNode(UNDERLINED));
        regular.add(new DefaultMutableTreeNode(STRIKE_THROUGH));
        root.add(regular);
        DefaultMutableTreeNode messages = new DefaultMutableTreeNode(MESSAGES + " (5 messages)");
        messages.add(new DefaultMutableTreeNode(ERROR_STRING));
        messages.add(new DefaultMutableTreeNode(UNDERLINED));
        messages.add(new DefaultMutableTreeNode(STRIKE_THROUGH));
        root.add(messages);
        DefaultTreeModel model = new DefaultTreeModel(root);
        JTree tree = new JTree(model) {
            public Dimension getPreferredScrollableViewportSize() {
                return new Dimension(300, 100);
        _tree = tree;
        tree.setCellRenderer(getStyledTreeCellRenderer());
        tree.setUI(new CustomizeTreeUI());
//        tree.setCellRenderer(getTreeCellRenderer());
        tree.setShowsRootHandles(true);
        tree.setRootVisible(false);
        panel.add(new JScrollPane(tree));
        panel.setBorder(BorderFactory.createCompoundBorder(BorderFactory.createTitledBorder(
                new PartialLineBorder(Color.gray, 1, true), " StyledLabel used as TreeCellRenderer ",
                TitledBorder.CENTER, TitledBorder.CENTER), BorderFactory.createEmptyBorder(6, 4, 4, 4)));
        return panel;
    private TreeCellRenderer getTreeCellRenderer() {
        return new TreeCellRenderer() {
            public Component getTreeCellRendererComponent(JTree tree, Object value, boolean selected, boolean expanded, boolean leaf, int row, boolean hasFocus) {
                String text = value.toString();
                JLabel label = new JLabel(text);
                if (text.startsWith(ADD_ICON)) {
                    label.setIcon(IconsFactoryDemo.getImageIcon(IconsFactoryDemo.CollapsiblePane.COMPUTER));
                    label.setIcon(null);
                return label;
    private StyledTreeCellRenderer getStyledTreeCellRenderer() {
        return new StyledTreeCellRenderer() {
            protected void customizeStyledLabel(JTree tree, Object value, boolean sel, boolean expanded, boolean leaf, int row, boolean hasFocus) {
                super.customizeStyledLabel(tree, value, sel, expanded, leaf, row, hasFocus);
                String text = getText();
                setBorder(BorderFactory.createEmptyBorder(0, 2, 0, 2));
                    setIcon(null);
                StyledLabelDemo.this.customizeStyledLabel(this, text);
    private JComponent createTablePanel() {
        DefaultTableModel model = new DefaultTableModel(0, 2) {
            public Class<?> getColumnClass(int columnIndex) {
                return String.class;
        model.addRow(new String[]{SEVERE + " (10 warnings)", ERROR_STRING});
        model.addRow(new String[]{REGULAR + " (2 warnings)", UNDERLINED});
        model.addRow(new String[]{MESSAGES + " (5 messages)", STRIKE_THROUGH});
        final JideTable table = new JideTable(model);
        table.setColumnAutoResizable(true);
        table.getColumnModel().getColumn(0).setPreferredWidth(200);
        table.setAutoResizeMode(JTable.AUTO_RESIZE_OFF);
        table.setDefaultRenderer(String.class, new StyledTableCellRenderer() {
            protected void customizeStyledLabel(JTable table, Object value, boolean isSelected, boolean hasFocus, int row, int column) {
                super.customizeStyledLabel(table, value, isSelected, hasFocus, row, column);
                setIcon(null);
        panel.add(new JScrollPane(table));
        table.setPreferredScrollableViewportSize(new Dimension(300, 100));
                new PartialLineBorder(Color.gray, 1, true), " StyledLabel used as TableCellRenderer ",
        return panel;
    private JComponent createListPanel() {
        DefaultListModel listModel = new DefaultListModel();
        listModel.addElement(SEVERE + " (10 warnings)");
        listModel.addElement(REGULAR + " (2 warnings)");
        listModel.addElement(MESSAGES + " (5 warnings)");
        listModel.addElement(ERROR_STRING);
        listModel.addElement(UNDERLINED);
        listModel.addElement(STRIKE_THROUGH);
        JList list = new JList(listModel) {
        list.setCellRenderer(new StyledListCellRenderer() {
            protected void customizeStyledLabel(JList list, Object value, int index, boolean isSelected, boolean cellHasFocus) {
                super.customizeStyledLabel(list, value, index, isSelected, cellHasFocus);
                setIcon(null);
        panel.add(new JScrollPane(list));
                new PartialLineBorder(Color.gray, 1, true), " StyledLabel used as  ListCellRenderer ",
        return panel;
    private JComponent createLabelsPanel() {
        StyledLabel javaTM = new StyledLabel("JavaTM");
        javaTM.addStyleRange(new StyleRange(4, 2, Font.PLAIN, StyleRange.STYLE_SUPERSCRIPT));
        StyledLabel co2 = new StyledLabel("CO2");
        co2.addStyleRange(new StyleRange(0, 2, Font.PLAIN, Color.BLUE));
        co2.addStyleRange(new StyleRange(2, -1, Font.PLAIN, Color.BLUE, StyleRange.STYLE_SUBSCRIPT));
        StyledLabel bold = new StyledLabel("Bold");
        bold.addStyleRange(new StyleRange(Font.BOLD, Color.BLACK));
        StyledLabel italic = new StyledLabel("Italic");
        italic.addStyleRange(new StyleRange(Font.ITALIC, Color.GRAY));
        StyledLabel error = new StyledLabel("Error");
        error.addStyleRange(new StyleRange(Font.PLAIN, Color.BLACK, StyleRange.STYLE_WAVED, Color.RED));
        StyledLabel background = new StyledLabel("Background");
        background.addStyleRange(new StyleRange(0, 4, Font.PLAIN, Color.BLACK, Color.YELLOW, StyleRange.STYLE_WAVED, Color.RED));
        background.addStyleRange(new StyleRange(4, 6, Font.PLAIN, Color.BLACK, Color.CYAN, StyleRange.STYLE_UNDERLINED, Color.BLUE));
        StyledLabel dotted = new StyledLabel("Dotted");
        dotted.addStyleRange(new StyleRange(Font.PLAIN, Color.BLACK, StyleRange.STYLE_DOTTED, Color.RED));
        StyledLabel strikethrough = new StyledLabel("Strikethrough");
        strikethrough.addStyleRange(new StyleRange(Font.PLAIN, Color.BLUE, StyleRange.STYLE_STRIKE_THROUGH, Color.BLACK));
        StyledLabel underlined = new StyledLabel("Underlined");
        underlined.addStyleRange(new StyleRange(Font.PLAIN, Color.BLUE, StyleRange.STYLE_UNDERLINED, Color.BLACK));
        StyledLabel doubleStrikethrough = new StyledLabel("Double Strikethrough");
        doubleStrikethrough.addStyleRange(new StyleRange(Font.PLAIN, Color.BLUE, StyleRange.STYLE_DOUBLE_STRIKE_THROUGH, Color.BLACK));
        StyledLabel twoStyles = new StyledLabel("Strikethrough and Underlined");
        twoStyles.addStyleRange(new StyleRange(Font.PLAIN, Color.RED, StyleRange.STYLE_STRIKE_THROUGH | StyleRange.STYLE_UNDERLINED, Color.BLACK));
        StyledLabel customizedUnderlined = new StyledLabel("Customized Underlined");
        customizedUnderlined.addStyleRange(new StyleRange(Font.PLAIN, Color.BLACK, StyleRange.STYLE_UNDERLINED, Color.BLACK,
                new BasicStroke(1.0f, BasicStroke.CAP_SQUARE, BasicStroke.JOIN_ROUND, 1.0f, new float[]{6, 3, 0, 3}, 0)));
        StyledLabel mixed = new StyledLabel("Mixed Underlined Strikethrough Styles");
        mixed.addStyleRange(new StyleRange(0, 5, Font.BOLD, Color.BLUE));
        mixed.addStyleRange(new StyleRange(6, 10, Font.PLAIN, Color.BLACK, StyleRange.STYLE_UNDERLINED));
        mixed.addStyleRange(new StyleRange(17, 13, Font.PLAIN, Color.RED, StyleRange.STYLE_STRIKE_THROUGH));
        StyledLabel disabedMixed = new StyledLabel("Mixed Underlined Strikethrough (Disabled)");
        disabedMixed.addStyleRange(new StyleRange(0, 5, Font.BOLD, Color.BLUE));
        disabedMixed.addStyleRange(new StyleRange(6, 10, Font.PLAIN, Color.BLACK, StyleRange.STYLE_UNDERLINED));
        disabedMixed.setEnabled(false);
        JPanel panel = new JPanel();
        panel.setLayout(new GridLayout(0, 2, 10, 10));
        panel.add(javaTM);
        panel.add(co2);
        panel.add(bold);
        panel.add(italic);
        panel.add(error);
        panel.add(background);
        panel.add(dotted);
        panel.add(underlined);
        panel.add(strikethrough);
        panel.add(doubleStrikethrough);
        panel.add(twoStyles);
        panel.add(customizedUnderlined);
        panel.add(mixed);
        panel.add(disabedMixed);
                new PartialLineBorder(Color.gray, 1, true), " StyledLabel Examples ",
        return panel;
    private void customizeStyledLabel(StyledLabel label, String text) {
        if (text.startsWith(SEVERE)) {
            label.addStyleRange(new StyleRange(0, SEVERE.length(), Font.BOLD, Color.RED));
            label.addStyleRange(new StyleRange(SEVERE.length(), -1, Font.ITALIC | Font.BOLD, Color.GRAY));
        else if (text.startsWith(REGULAR)) {
            label.addStyleRange(new StyleRange(0, REGULAR.length(), Font.BOLD));
            label.addStyleRange(new StyleRange(REGULAR.length(), -1, Font.ITALIC | Font.BOLD, Color.GRAY));
        else if (text.startsWith(MESSAGES)) {
            label.addStyleRange(new StyleRange(0, MESSAGES.length(), Font.PLAIN));
            label.addStyleRange(new StyleRange(MESSAGES.length(), -1, Font.ITALIC, Color.GRAY));
        else if (text.startsWith(ERROR_STRING)) {
            label.addStyleRange(new StyleRange(Font.PLAIN, Color.RED, StyleRange.STYLE_WAVED, Color.RED));
        else if (text.startsWith(UNDERLINED)) {
            label.addStyleRange(new StyleRange(Font.PLAIN, StyleRange.STYLE_UNDERLINED));
        else if (text.startsWith(STRIKE_THROUGH)) {
            label.addStyleRange(new StyleRange(Font.PLAIN, Color.GRAY, StyleRange.STYLE_STRIKE_THROUGH, Color.RED));
        return "B15.StyledLabel";
        System.out.println("compiled");
        showAsFrame(new StyledLabelDemo());
    class CustomizeTreeUI extends BasicTreeUI {
        public CustomizeTreeUI() {
            super();
        public void updateTreeCashSize() {
            treeState.invalidateSizes();
Users browsing this forum: No registered users and 76 guests
