Java error at startup
Postby LotusE » Fri Nov 20, 2009 12:32 am
I don't know if this is the right forum (correct me if I'm wrong) but a client of us gets an error message every time he starts up his pc. The error occurred after an automatic update of java.
this is the error:
java.lang.NoClassDefFoundError: com/jidesoft/utils/Lm
at de.sva.autostart.AutoStarter.main(AutoStarter.java:297)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
Caused by: java.lang.ClassNotFoundException: com.jidesoft.utils.Lm
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
Does anybody know how I can get rid of this error message?
Thanks in advance!
Cheers
LotusE
LotusE
Re: Java error at startup
Postby JIDE Support » Fri Nov 20, 2009 9:16 am
It sounds like jide-common.jar is not in the application's class path as com.jidesoft.utils.Lm is a class in jide-common.jar. Please note, jide-oss-xxx.jar doesn't have Lm class so you can't replace jide-common.jar with jide-oss-xxx.jar if you are JIDE paid customer.
Postby LotusE » Wed Nov 25, 2009 4:24 am
thanks for your answer. Unfortunately, I don't really understand it. Is there a way to find out which program is causing the error or which program is using this jar file? So I can track down the program that causes the error.
thanks in advance!
Cheers
Steve
LotusE
Postby Walter Laan » Wed Nov 25, 2009 7:39 am
Jide makes only a reusable part of a computer program which other businesses use to build actual programs, but the Jide part seems to be missing in your case.
Possibly the actual program that giving the error is made by sva.de according to the error, but they also might be just another 'part of a program' vendor.
To find the actual program, go start -> run -> type msconfig and press enter -> look at the start up tab to see the programs that automatically start up.
You're most likely looking for a exe program in the Program Files folder. Then re-install that program and/or contact the actual vendor of it.
Walter Laan
Postby JIDE Support » Wed Nov 25, 2009 8:26 am
Thanks Walter. Your post is detail and easy to follow.
