JideSplitButton with Action
Postby Walter Laan » Thu Nov 19, 2009 6:31 am
below I've a sub class of JideSplitButton with the following changes:
1) Use Action.LARGE_ICON_KEY when available since (I think) the split button is more a button than a menu (which uses small icon always)
2) Added support for a SPLIT_BUTTON_ENABLED action property
I think the first is OK to be committed to common JideSplitButton, as I don't think someone would use it in a menu (preferring a small icon)?
The second is a bit incomplete as there is also a setButtonSelected() but that is more a view property (whether the button or the menu part is selected) I think?
public class CustomJideSplitButton extends JideSplitButton {
    public static final String SPLIT_BUTTON_ENABLED = "JideSplitButtonEnabled";
    public CustomJideSplitButton(Action action) {
        super(action);
    protected void configurePropertiesFromAction(Action action) {
        super.configurePropertiesFromAction(action);
        setButtonEnabled(isSplitButtonEnabled(action));
        doSetIconFromAction(action);
    protected void doSetIconFromAction(Action action) {
        // setIconFromAction is package private in AbstractButton
        Icon icon = null;
        if (action != null) {
            icon = (Icon) action.getValue(Action.LARGE_ICON_KEY);
            if (icon == null) {
                icon = (Icon) action.getValue(Action.SMALL_ICON);
        setIcon(icon);
    protected void actionPropertyChanged(Action action, String propertyName) {
        super.actionPropertyChanged(action, propertyName);
        if(SPLIT_BUTTON_ENABLED.equals(propertyName)) {
        else if (propertyName == Action.SMALL_ICON) {
            // smallIconChanged is package private in AbstractButton
            if(action.getValue(Action.LARGE_ICON_KEY) == null) {
        else if (propertyName == Action.LARGE_ICON_KEY) {
            // largeIconChanged is package private in AbstractButton
    public static boolean isSplitButtonEnabled(Action action) {
        if(action == null) {
        else {
            Object value = action.getValue(SPLIT_BUTTON_ENABLED);
            if(value instanceof Boolean) {
                return ((Boolean) value).booleanValue();
            else {
                return action.isEnabled();
Walter Laan
Re: JideSplitButton with Action
Postby JIDE Support » Thu Nov 19, 2009 9:06 am
In general, people will use it as a button but there are indeed cases that it could be used as a menu which it acts like a JMenu on JPopupMenu except the menu item itself can be clicked. So we will keep the current design for now.
Postby JIDE Support » Thu Nov 19, 2009 2:28 pm
Thanks for code sharing. We will include your code in 2.8.1 since your design covers most of the cases for JideSplitButton and provides an overridable method for the customer to customize it further.
Postby JIDE Support » Fri Dec 04, 2009 3:25 pm
Just so you know, your code is included in 2.8.1 release.
Users browsing this forum: No registered users and 81 guests
