JidePopup window grows infinitely taller
Postby mcdev1 » Mon Nov 09, 2009 2:45 pm
I noticed in my application that each time a button that displays a JidePopup is clicked, the popup's window gets slightly taller, so that displaying the popup several times results in a noticeably larger popup. This is happening in the demo (PopupDemo) also.
mcdev1
Re: JidePopup window grows infinitely taller
Postby JIDE Support » Mon Nov 09, 2009 6:08 pm
We did fix an issue in 2.7.1. The bug report is http://www.jidesoft.com/forum/viewtopic.php?f=5&t=7921&p=39410#p39410. Please try a release later than 2.7.1 if you are on earlier release.
Postby mcdev1 » Mon Nov 09, 2009 7:12 pm
I was using version 2.7.4 and I upgraded to 2.8.0 and I can still reproduce it with this small test case.
import com.jidesoft.popup.JidePopup;
import java.awt.event.*;
public class JidePopupTest {
        final JFrame frame = new JFrame();
        final JButton button = new JButton("Show popup");
        frame.getContentPane().add(button);
        final JidePopup popup = new JidePopup();
        button.addActionListener(new ActionListener() {
//                popup.setPreferredPopupSize(null);
                popup.showPopup(button);
        final JPanel popupContentPane = new JPanel();
        popupContentPane.add(new JLabel("popup content pane"));
        popup.setContentPane(popupContentPane);
        frame.setSize(200, 100);
The workaround of setPreferredPopupSize(null) still works.
The demo on the main page (http://www.jidesoft.com/products/1.4/jide_demo.jnlp) has this problem also, and I assume it is using the latest version also since it does not seem to list a library version.
mcdev1
Postby JIDE Support » Mon Nov 09, 2009 10:27 pm
Thanks for your test case. We reproduced it and will fix it in 2.8.1 and 2.7.6.
Postby JIDE Support » Fri Nov 20, 2009 6:16 pm
Just so you know, this is fixed in 2.7.6 release.
Postby JIDE Support » Fri Dec 04, 2009 3:48 pm
Just so you know, this is also fixed in 2.8.1 release.
