Disable MultiplePageDialog
Postby mohanv » Mon Oct 26, 2009 10:28 am
I am using MultiplePageDialog [jide-oss-2.7.2.jar] inside one of my JPanel. I would like to disable the MultiplePageDialog so that user can not navigate/click on the MultiplePageDialog.
I used MultiplePageDialog#setEnabled(false) but it is not working.
Please suggest a workaround for this.
Thank you
- Mohana
mohanv
Re: Disable MultiplePageDialog
Postby JIDE Support » Mon Oct 26, 2009 12:45 pm
May I ask how you add a dialog into a JPanel? Swing would throw an IllegalArgumentException in this case. It would help if you can share with me a test case to demonstrate the issue.
Postby mohanv » Mon Oct 26, 2009 8:55 pm
Actually, I did not add the MultiplePageDialog directly to panel but by retrieving multiplePageDialog.getIndexPanel() and multiplePageDialogPane.getPagesPanel().
Let me know if you need more information.
Could you please suggest me a way to avoid user navigation/actions?
Thank you
- Mohan
mohanv
Postby JIDE Support » Tue Oct 27, 2009 4:54 pm
Please try override all three MultiplePageDialog#setCurrentPage() to empty method. Then, the customer will not be able to navigate between pages. You can have another method to call super.setCurrentPage() to do it programmatically.
