CheckBoxTree with DigIn
Postby Bosk » Fri Oct 09, 2009 6:01 am
How to easy change CheckBoxThree behavior with DigIn. I need functionality similar as DigIn, but if undo parent we haven't checked childs DigIn remove selection from parent, but I want save this selection for parent.
1. If we set check in parent node - all childs under parent must be cheked.
2. If we remove check in all childs - parent node must be cheked.
3. If we remove check from parent - check from child must be removed.
4. If we set check for child but parent is uncheked, we must set check to parent.
Bosk
Re: CheckBoxTree with DigIn
Postby JIDE Support » Fri Oct 09, 2009 9:12 am
Please try extend CheckBoxTreeSelectionModel to create your own selection model. Since the item 2 in your request is kind of conflict with the concept of digIn, I cannot see an easy way to achieve this in just a few lines. The issue is that, if all children are unchecked, which selection path will you save in the selection model? If you save the parent as checked, the children nodes will be painted as checked automatically in next painting. Hence, you probably have to add a flag to distinguish the normal parent check and the empty parent check and control the behavior everywhere with the flag.
Postby Bosk » Tue Oct 13, 2009 6:30 am
I try to extend CheckBoxTreeSelectionModel.
public class MyCheckBoxTreeSelectionModel extends CheckBoxTreeSelectionModel
   public MyCheckBoxTreeSelectionModel(TreeModel model)
      super(model);
But I don't understand in which methods I must use flags. I try to create my own method
public void removeSelectionPaths(TreePath[] paths, boolean doFireEvent)
it's don't help me, because toggleRemoveSelection and delegateRemoveSelectionPaths is not visible. May be i'm moving in a wrong way?
Bosk
Postby JIDE Support » Tue Oct 13, 2009 8:42 am
As we said, it's not easy to do so due to the reason we stated in the previous post. Please feel free to create your own selection model with JIDE CheckBoxTreeSelectionModel source code at https://jide-oss.dev.java.net/.
Users browsing this forum: No registered users and 70 guests
