CheckBoxTree Lazy loading?
Postby hemna » Mon Sep 28, 2009 4:14 pm
Is there a way that I could implement a checkboxtree that included lazy loading of leaf nodes?
Say I have a tree that when created, it only loads the first level nodes as all collapsed. Then when a user clicks to expand one of the nodes, a method is called to fetch the leaf
nodes from another source and then inserts them, then displays them. I need to do this instead of loading the entire hierarchy at once for performance reasons. I have a tree with
thousands of nodes and I won't want to load them all up front.
Walt
hemna
Re: CheckBoxTree Lazy loading?
Postby JIDE Support » Mon Sep 28, 2009 4:42 pm
Yes. You can do that just imaging it as a normal JTree. However, for digIn mode, you probably need do more control so that when you select a parent node and expand it, all child nodes could be selected.
Postby pvbemmel » Mon May 28, 2012 8:41 am
I want to show the filesystem using a CheckBoxTree with digin behaviour.
The filesystem does not have to be editable.
I have code that works; it uses FileTreeNode which I extended from DefaultMutableTreeNode.
FileTreeNode creates FileTreeNode instances for its children, only when asked for a child through
method getChildAt(int index) .
It works, but is rather slow, when compared to a javax.swing.JTree .
With digin enabled, the CheckBoxTree creates way more FileTreeNode instances than
the JTree, when showing the same part of the filesystem.
Is there a way to make the creation of FileTreeNode instances more lazy ?
I have enclosed some files. Two of these files contain main(String[]) to run test programs:
FileTreeFrame.java: test program using JTree and FileTreeNode
CheckBoxFileTreeFrame.java: test program using CheckBoxTree and FileTreeNode
Anybody any idea to increase speed, be more lazy ?
import java.io.*;
import java.util.*;
import java.util.logging.*;
import javax.swing.tree.*;
@SuppressWarnings("serial")
public class FileTreeNode extends DefaultMutableTreeNode {
  private static class FileComparator implements Comparator<File> {
    public int compare(File o1, File o2) {
      return o1.getName().compareTo(o2.getName());
  private static Logger getLogger() {
    return Logger.getLogger(FileTreeNode.class.getName());
  private static final FileComparator fileComparator;
  private static final DirFileFilter dirFileFilter;
  private static final FileFileFilter fileFileFilter;
  static {
    fileComparator = new FileComparator();
    dirFileFilter = new DirFileFilter();
    fileFileFilter = new FileFileFilter();
  /** Children have been constructed. */
  private boolean initialized;
  private File file;
  public FileTreeNode(File file) {
     super(file);
     getLogger().log(Level.INFO, file.getPath());
     this.file = file;
     setAllowsChildren(file.isDirectory());
     initialized = false;
  public boolean getAllowsChildren() {
    return file.isDirectory();
  public TreeNode getChildAt(int index) {
    assertChildren();
    return super.getChildAt(index);
  private void assertChildren() {
    if(initialized) {
      return;
    initialized = true;
    if(!file.isDirectory()) {
      return;
    List<File> dirs = Arrays.asList(file.listFiles(dirFileFilter));
    Collections.sort(dirs, fileComparator);
    List<File> files = Arrays.asList(file.listFiles(fileFileFilter));
    Collections.sort(files, fileComparator);
    List<File> all = new ArrayList<File>();
    all.addAll(dirs);
    all.addAll(files);
    for(File f : all) {
      FileTreeNode child = new FileTreeNode(f);
      add(child);
      child.setParent(this);
  public int getChildCount() {
    if(file.isDirectory()) {
      if(initialized) {
        return super.getChildCount();
      else {
        String[] names = file.list();
        return names==null ? 0 : names.length;
    return 0;
  public boolean isLeaf() {
      if(initialized) {
        return super.isLeaf();
      else {
        return names==null ? true : (names.length>0);
    else {
import java.io.*;
import com.jidesoft.plaf.*;
import com.jidesoft.swing.*;
public class CheckBoxFileTreeFrame extends JFrame {
  private CheckBoxTree fileTree;
  private TreeModel fileSystemModel;
  public CheckBoxFileTreeFrame(String directory) {
    super("CheckBoxFileFileTreeFrame");
    FileTreeNode top = new FileTreeNode(new File(directory));
    fileSystemModel = new DefaultTreeModel(top, true);
    fileTree = new CheckBoxTree(fileSystemModel) {
      public String convertValueToText(Object value, boolean selected,
          boolean expanded, boolean leaf, int row, boolean hasFocus) {
        FileTreeNode node = (FileTreeNode) value;
        File file = (File) node.getUserObject();
        return file.getName();
    fileTree.setEditable(false);
    fileTree.getCheckBoxTreeSelectionModel().setDigIn(true);
    getContentPane().add(new JScrollPane(fileTree));
    setDefaultCloseOperation(EXIT_ON_CLOSE);
    setSize(640, 480);
    setLocationRelativeTo(null);
    setVisible(true);
  public static void main(String args[]) {
      public void run() {
        catch (Exception e) {
          e.printStackTrace();
        new CheckBoxFileTreeFrame("c:\\");
import java.io.*;
public class FileTreeFrame extends JFrame {
  private JTree fileTree;
  private DefaultTreeModel fileSystemModel;
  public FileTreeFrame(String directory) {
    super("JTree FileSystem Viewer");
    fileTree = new JTree(fileSystemModel) {
        FileTreeNode node = (FileTreeNode)value;
        File file = (File)node.getUserObject();
    setSize(640, 480);
    setVisible(true);
      public void run() {
        new FileTreeFrame("c:\\");
import java.io.*;
public class DirFileFilter implements FileFilter {
  public boolean accept(File file) {
import java.io.*;
public class FileFileFilter implements FileFilter {
    return file.isFile();
pvbemmel
Postby pvbemmel » Tue May 29, 2012 5:43 am
After reading the first two posts in this thread again, I realize that those posts deal with the same problem that I have.
Earlier I thought that hemna had a dynamic model, but now I realize that basically he has a static model, which is large,
and that he wants to provide it to the CheckBoxTree piecewise (i.e. as a dynamic model), as a solution to performance problem.
Thus, the same problem as I have.
The solution suggested in the first two posts, seem to me like a workaround for a bug in the CheckBoxTree.
Couldn't the CheckBoxTree take care of this problem, by not creating nodes so aggressively ?
Paul.
pvbemmel
Postby pvbemmel » Tue May 29, 2012 6:30 am
I solved the performance problem for my file system CheckBoxTree with digin true.
Now my code is as fast as the normal JTree.
I have used example code from http://docs.oracle.com/javase/tutorial/ ... /tree.html
from the "How to Load Children Lazily" section.
See attached code for my program.
Paul.
import java.io.*;
import java.util.*;
  static {
  private File file;
     super(file);
     this.file = file;
//  assertChildren();
  public void assertChildren(DefaultTreeModel model) {
    if(initialized) {
      return;
    initialized = true;
      return;
    all.addAll(dirs);
    all.addAll(files);
    for(File f : all) {
      model.insertNodeInto(child, this, getChildCount());
    if(initialized) {
    else {
      return 0;
    if(initialized) {
    else {
      return true;
import java.io.*;
import javax.swing.event.*;
    top.assertChildren(fileSystemModel);
    fileTree.addTreeWillExpandListener(new MyTreeWillExpandListener());
    setSize(640, 480);
    setVisible(true);
  public class MyTreeWillExpandListener implements TreeWillExpandListener {
    public void treeWillExpand(TreeExpansionEvent event)
        throws ExpandVetoException {
      TreePath treePath = event.getPath();
      FileTreeNode ftNode = (FileTreeNode)treePath.getLastPathComponent();
      ftNode.assertChildren(fileSystemModel);
    public void treeWillCollapse(TreeExpansionEvent event)
      public void run() {
import java.io.*;
import java.io.*;
pvbemmel
Postby pvbemmel » Wed May 30, 2012 2:30 am
I've updated the code, to now show a CheckBoxTree of all roots as listed by File.listRoots() .
Because I'm so pleased with the result, I have enclosed a zip with the sources .
Hope others my find this useful code.
Paul van Bemmelen.
jideFileSystemTree.zip
(6.32 KiB) Downloaded 3764 times
pvbemmel
Postby JIDE Support » Wed May 30, 2012 2:28 pm
Thanks for your sharing. We will consider include your code into our package if possible and granted the permission by you.
Postby pvbemmel » Thu May 31, 2012 4:14 am
Permission granted, provided that any copyright you put on it doesn't restrict access to it.
The code doesn't yet have functionality to find out what checkboxes are checked. I still have to look into that.
Kind regards,
Paul.
pvbemmel
Postby pvbemmel » Thu May 31, 2012 6:17 am
That functionality is simple: use tree.getCheckBoxTreeSelectionModel() .
pvbemmel
Postby JIDE Support » Thu May 31, 2012 2:25 pm
Got it.
