CheckboxTree
CheckboxTree
Postby hemna » Wed Jul 29, 2009 10:45 am
Is there a way to have the tree not show the checkboxes on the leaf nodes and the root node?
I have a 2 level dataset that I want to show in a checkbox tree, but only have checkboxes on the top level.
I don't want a checkbox on the root or level 2 nodes.
* root
--Level 1
   -- level 2
 --Level 1a
   -- level 2a
Also, when the tree has Level 1 nodes that are unchecked, is there a way to show that level 1 and all child level 2 nodes as greyed or disabled?
hemna
Re: CheckboxTree
Postby JIDE Support » Wed Jul 29, 2009 11:07 am
Please try override CheckBoxTree#isCheckBoxVisible(TreePath) like the sample code to set the visibility of each path.
                return path.getPathCount() == 2;
Please set your own cell renderer to set the rows to gray.
        DefaultTreeCellRenderer renderer = new DefaultTreeCellRenderer() {
            public Component getTreeCellRendererComponent(JTree tree, Object value, boolean sel, boolean expanded, boolean leaf, int row, boolean hasFocus) {
                Component rendererComponent = super.getTreeCellRendererComponent(tree, value, sel, expanded, leaf, row, hasFocus);
                TreePath path = tree.getPathForRow(row);
                if (path != null && path.getPathCount() != 2) {
                    rendererComponent.setForeground(Color.gray);
                return rendererComponent;
        _tree.setCellRenderer(renderer);
Re: CheckboxTree
Postby hemna » Wed Jul 29, 2009 1:17 pm
Wow thanks for the quick reply. I tried both items and they work great.
I just need to re-enable the leaf nodes when the checkbox is checked again.
hemna
Re: CheckboxTree
Postby JIDE Support » Wed Jul 29, 2009 1:21 pm
Please try use CheckBoxTreeSelectionModel#isPathSelected(TreePath, boolean) to check the selection state of the path.
Re: CheckboxTree
Postby hemna » Wed Jul 29, 2009 1:54 pm
the docs state that CheckBoxTreeSelectionModel#isPathSelected tells weither a path is selected, but not if it's checked.
If the level 1 node is checked, then I need to enable all level 2 (leaf) nodes. If the path is unchecked, then I need to disable all leaf nodes.
hemna
Re: CheckboxTree
Postby hemna » Wed Jul 29, 2009 1:59 pm
Also, where do I add code to detect when the checkbox has been checked/unchecked. So I need to add another special listener for the checkbox itself?
hemna
Re: CheckboxTree
Postby JIDE Support » Wed Jul 29, 2009 2:24 pm
Please try the following code.
                if (path != null && path.getPathCount() != 2 && !((CheckBoxTree) tree).getCheckBoxTreeSelectionModel().isPathSelected(path, true)) {
Re: CheckboxTree
Postby hemna » Wed Jul 29, 2009 3:12 pm
ok I figured out how to add a listener to pickup checkbox changes. Now I need to grey out/disable all leaf nodes from a path once I detect a checkbox has been unchcked.
Here is my checkbox code
categoryTree.getCheckBoxTreeSelectionModel().addTreeSelectionListener(new TreeSelectionListener() {
      public void valueChanged(TreeSelectionEvent e) {
         boolean checked = false;
         // your code here.
         TreePath checkedPath = e.getPath();
         if (checkedPath != null) {
            if (categoryTree.getCheckBoxTreeSelectionModel().isPathSelected(checkedPath)) {
               checked = true;
               checked = false;
hemna
Re: CheckboxTree
Postby JIDE Support » Wed Jul 29, 2009 3:22 pm
Can you please give the code in my previous post a try? In that way, you don't even have to listen to the event.
Re: CheckboxTree
Postby hemna » Wed Jul 29, 2009 4:02 pm
Your previous example works great. I have one small difference is that I'm disabling the node instead of marking it grey with the hopes that you can't select it.
            //rendererComponent.setForeground(Color.gray);
            rendererComponent.setEnabled(false);
The node does get disabled, but I have 2 issues
1) when it's disabled, the node doesn't render the file icon to the left of the node. When the checkbox is checked, and the nodes are enabled again, they get a file icon on the left.
Shouldn't the file icon be there in both cases?
2) when the node is disabled, I can still select the node, but the selection looks quite odd...
hemna
Re: CheckboxTree
Postby hemna » Wed Jul 29, 2009 4:39 pm
ok for now, I'm going back to just marking each node as grey.
How do I mark which nodes are checked and unchecked when I'm building the tree of nodes prior to adding them to the model?
//get the list of categories.
String[] categories = myclass.getList();
for (int x=0; x<categories.length; x++) {
   DefaultMutableTreeNode categoryNode = new DefaultMutableTreeNode(categories[x]);
   if (myclass.isSelected(categories[x])) {
      //how do I mark this node as CHECKED?
      //HERE
   //get the groups for each category
   String[] groups = myclass.getSubList(categories[x]);
   for (int y=0; y<groups.length; y++) {
      DefaultMutableTreeNode groupNode = new DefaultMutableTreeNode(groups[y]);
      categoryNode.add(groupNode);
   rootNode.add(categoryNode);
DefaultTreeModel treeModel = new DefaultTreeModel(root);
categoryTree  = new CategoryCheckBoxTree();
categoryTree.setModel(treeModel);
hemna
Re: CheckboxTree
Postby JIDE Support » Wed Jul 29, 2009 5:24 pm
1, Regarding the enable/disable issue, I cannot reproduce the icon losing behavior. Please use our CheckBoxTreeDemo plus the following code and see if you can get the behavior you want.
//                    rendererComponent.setForeground(Color.gray);
        renderer.setLeafIcon(IconsFactory.getImageIcon(QuickFilterTreeDemo.class, "/icons/song.png"));
        renderer.setClosedIcon(IconsFactory.getImageIcon(QuickFilterTreeDemo.class, "/icons/album.png"));
        renderer.setOpenIcon(IconsFactory.getImageIcon(QuickFilterTreeDemo.class, "/icons/album.png"));
2, Please try use CheckBoxTree#getCheckBoxTreeSelectionModel()#addSelectionPaths(TreePath[]) to add the selection after you create the CheckBoxTree.
Re: CheckboxTree
Postby hemna » Thu Jul 30, 2009 3:02 pm
Ok so I mostly have this working. I can initially set the list of checked items. But I need to reset the list of checked items behinds the scenes due to other user actions. I've found that if I do the following, that all of my selections are removed, but the new selections aren't set for some reason.
categoryTree.getCheckBoxTreeSelectionModel().removeSelectionPaths(
               categoryTree.getCheckBoxTreeSelectionModel().getSelectionPaths());
categoryTree.getCheckBoxTreeSelectionModel().addSelectionPaths(checkedCategoryPaths);
I have verified that the checkedCategoryPaths (which is a new TreePath[] list that is non empty) doesn't seem to work. Is this the proper way to reset a different list of checked nodes?
hemna
Re: CheckboxTree
Postby JIDE Support » Thu Jul 30, 2009 3:21 pm
It works for me. I tried to add the following line to our CheckBoxTreeDemo and it works fine. Would you please share with us a test case to demonstrate the issue?
        _tree.getCheckBoxTreeSelectionModel().addSelectionPaths(new TreePath[] {_tree.getPathForRow(1)});
Re: CheckboxTree
Postby hemna » Thu Jul 30, 2009 3:47 pm
does addSelectionPaths add new selections/checked checkboxes or does it replace the existing ones?
hemna
Re: CheckboxTree
Postby JIDE Support » Thu Jul 30, 2009 3:50 pm
It adds new selections without clearing existing ones. However, if in digIn mode, it could combine some selections internally. In both cases, visually it should just add new selections you passed into.
Re: CheckboxTree
Postby hemna » Thu Jul 30, 2009 4:37 pm
ok thanks. So I should be removing all the current ones first, then adding new ones, like I have in my previous posting?
hemna
Re: CheckboxTree
Postby JIDE Support » Thu Jul 30, 2009 4:41 pm
Yes. And if you always want to clear the previous selections, you can also try setSelectionPaths().
Re: CheckboxTree
Postby hemna » Thu Jul 30, 2009 5:30 pm
I just don't know what the problem is.
buildNodesFromCategories(model);
int size=selectedPathsMap.size();
checkedCategoryPaths = selectedPathsMap.values().toArray(new TreePath[size]);
//checkedCategoryPaths = categoryTree.getCheckBoxTreeSelectionModel().getSelectionPaths();
//categoryTree.getCheckBoxTreeSelectionModel().removeSelectionPaths(
    //categoryTree.getCheckBoxTreeSelectionModel().getSelectionPaths());
categoryTree.getCheckBoxTreeSelectionModel().setSelectionPaths(checkedCategoryPaths);
TreePath[] test = categoryTree.getCheckBoxTreeSelectionModel().getSelectionPaths();
categoryTree.getCheckBoxTreeSelectionModel().setSelectionPaths(test);
When I populate the test TreePath array and look at it in eclipse debug, it comes back as exactly as I'd suspect. It's correctly populated
[[Root, Foo], [Root, Bar]]
checkedCategoryPaths and test end up with the same values and look ok...but the tree ends up with nothing selected.
hemna
Re: CheckboxTree
Postby JIDE Support » Thu Jul 30, 2009 6:29 pm
The reason probably is that the TreeNode contained in your TreePath is not the same instance of the TreeNodes inside the Tree although they look similar. Please try populate the TreePath from the current Tree.
Re: CheckboxTree
Postby hemna » Thu Jul 30, 2009 6:51 pm
so I have to get all of the nodes in the tree, then get their TreePath objects, shove those in a TreePath[] and then call setSelectionPaths() ?
man...the docs just aren't clear. Do the docs state anywhere that you have to use the same instance of the TreePath objects that are already contained in the Tree?
Can you provide a sample of the "correct" way to reset the selected paths with new selections?
I'm a bit frustrated, but I really do appreciate the help. You guys have been great.
hemna
Re: CheckboxTree
Postby JIDE Support » Fri Jul 31, 2009 7:52 am
Please try the following code. Since CheckBoxTree is a subclass of JTree, we didn't describe much on the inherited behaviors on our documents. Anyway, we will improve our document here.
        TreeModel model = _tree.getModel();
        Object root = model.getRoot();
        int childCount = model.getChildCount(root);
        for (int i = 0; i < childCount; i++) {
            Object child = model.getChild(root, i);
            if (child instanceof DefaultMutableTreeNode) {
                if ("1".equals(((DefaultMutableTreeNode) child).getUserObject())) {
                    _tree.getCheckBoxTreeSelectionModel().addSelectionPath(new TreePath(((DefaultMutableTreeNode) child).getPath()));
Re: CheckboxTree
Postby hemna » Fri Jul 31, 2009 11:02 am
I'm having something else quite bizarre happening.
when I do
tree = new CheckBoxTree();
The debugger says there are 20 visible nodes. When the tree gets rendered I see these. I have no idea where they are coming from, unless the CheckBoxTree itself
populates it with sample nodes?!?
JTree
 Colors
  blue
  violet
  red
  yellow
 Sports
  basketball
  soccer
  football
  hockey
 Food
  hot dogs
  pizza
  ravioli
  bananas
1 line after new CheckBoxTree
hemna
Re: CheckboxTree
Postby JIDE Support » Fri Jul 31, 2009 12:10 pm
Yes. It comes from JTree if you don't pass any model into the constructor.
Re: CheckboxTree
Postby hemna » Fri Sep 11, 2009 3:17 pm
How can I insert a new node into an existing tree? Say my tree is constrained to 2 levels
Root
   + Level 1
       + Level2a
   + Level 1a
       + Level2b
       + Level2c
say I want to insert a new node Level2d under Level1a ? (resulting in)
Root
   + Level 1
       + Level2a
   + Level 1a
       + Level2b
       + Level2c
       + Level2d
or I want to insert a new Level2d node under level1b, which doesn't exist as well.
   + Level 1
       + Level2a
   + Level 1a
       + Level2b
       + Level2c
   + Level1b
       + Level 2d
hemna
Next
