Checkbox tree
Checkbox tree
Postby jamindhar » Sun Jul 19, 2009 2:38 am
I want to select all the check boxes by default in checkbox tree. how can i do that ...?
jamindhar
Re: Checkbox tree
Postby JIDE Support » Sun Jul 19, 2009 7:12 am
Please try the following codes:
        Object root = _tree.getModel().getRoot();
        _tree.getCheckBoxTreeSelectionModel().addSelectionPath(new TreePath(root));
Re: Checkbox tree
Postby RajaRajeswari_V » Sun Jul 19, 2009 8:20 am
is it possible to select only few paths by default..? we are creating a ui where the user can select few paths to display a diagram. whenever he wants to revisit the application we want to show them the previous selected paths..we are storing the selection in Hashset<TreePath>.is there any way to do this?
RajaRajeswari_V
Re: Checkbox tree
Postby JIDE Support » Sun Jul 19, 2009 8:26 am
Please try use TreeUtils#saveSelection/loadSelection to achieve your goal.
Re: Checkbox tree
Postby RajaRajeswari_V » Sun Jul 19, 2009 8:58 am
hi,
Thanks for your quick reply. but the treeutils.saveselction is returning the null. please send me any sample code to do this.
RajaRajeswari_V
Re: Checkbox tree
Postby JIDE Support » Sun Jul 19, 2009 12:57 pm
Some similar terms are hidden here. We probably mistook your request in previous post. Here are the clarification.
TreeUtils#saveSelection() returns the visual selections which changes the background of the selected item like other JTree.
yourCheckBoxTree.getCheckBoxTreeSelectionModel().getSelectionPaths() returns the check box selections which reflects the state of check boxes in the CheckBoxTree.
